Can bus shield ODB2
Hello all! I’m new to the forums but a few years tinker’er. For the last several years I’ve been slowly working on a project to create my own tailgate light bar for my truck. I was originally going to pull the 12volt signal off the 7 pin trailer connector and step it down to a safer voltage and isolated with opticouplers to interface my lights with the truck signals. Then I learned about can-bus which would cut down on the wires I have to run. I have a canbus shield and a db9 to odbII port cable. I’m able to see can “data” when I run a default can receiver from any can bus library. My trouble is i cant see specific data. I cannot communicate with the canbus to send me specific data such as RPM,Speed, gear, signals etc… I reduced the canbus speed to 33kbps (not all libraries allow this) and on first run of arduino my truck will show me errors either 4wd needs service or tcs needs service basically interference.
my canbus shield uses mcp2515 mcp255 chips. I have a gmc sierra 1500 whic should use the SAE J1850 VPW protocol. I have cut the CANH jumper as if i left it intact i couldn’t receive any data (too many can devices) the code im trying to use is
#include <Canbus.h>
char UserInput;
int data;
char buffer[456];  //Data will be temporarily stored to this buffer before being written to the file
//********************************Setup Loop*********************************//
void setup(){
Serial.println("CAN-Bus Demo");
if(Canbus.init(CANSPEED_125))  /* Initialise MCP2515 CAN controller at the specified speed */
    Serial.println("CAN Init ok");
  } else
    Serial.println("Can't init CAN");
Serial.println("Please choose a menu option.");
Serial.println("1.Speed");
Serial.println("2.RPM");
Serial.println("3.Throttle");
Serial.println("4.Coolant Temperature");
Serial.println("5.O2 Voltage");
Serial.println("6.MAF Sensor");
//********************************Main Loop*********************************//
void loop(){
while(Serial.available()){
   UserInput = Serial.read();
if (UserInput=='1'){
 Canbus.ecu_req(VEHICLE_SPEED, buffer);
 Serial.print("Vehicle Speed: ");
 Serial.println(buffer);
else if (UserInput=='2'){
 Canbus.ecu_req(ENGINE_RPM, buffer);
 Serial.print("Engine RPM: ");
else if (UserInput=='3'){
 Canbus.ecu_req(THROTTLE, buffer);
 Serial.print("Throttle: ");
else if (UserInput=='4'){
 Canbus.ecu_req(ENGINE_COOLANT_TEMP, buffer);
 Serial.print("Engine Coolant Temp: ");
else if (UserInput=='5'){
 Canbus.ecu_req(O2_VOLTAGE, buffer);
 Serial.print("O2 Voltage: ");
else if (UserInput=='6'){
 Canbus.ecu_req(MAF_SENSOR, buffer);
 Serial.print("MAF Sensor: ");
  Serial.println(UserInput);
  Serial.println("Not a valid input.");
  Serial.println("Please enter a valid option.");
also
#include <SPI.h>
#include <CAN.h>
  while (!Serial);
  Serial.println("CAN Receiver");
  // start the CAN bus at 500 kbps
  if (!CAN.begin(500E3)) {
    Serial.println("Starting CAN failed!");
    while (1);
  // try to parse packet
  int packetSize = CAN.parsePacket();
  if (packetSize) {
    // received a packet
    Serial.print("Received ");
    if (CAN.packetExtended()) {
      Serial.print("extended ");
    if (CAN.packetRtr()) {
      // Remote transmission request, packet contains no data
      Serial.print("RTR ");
    Serial.print("packet with id 0x");
    Serial.print(CAN.packetId(), HEX);
      Serial.print(" and requested length ");
      Serial.println(CAN.packetDlc());
      Serial.print(" and length ");
      Serial.println(packetSize);
      // only print packet data for non-RTR packets
      while (CAN.available()) {
        Serial.print((char)CAN.read());
to receive specific data based on hex address
#include <SPI.h>
#include "mcp_can.h"
// the cs pin of the version after v1.1 is default to D9
// v0.9b and v1.0 is default D10
const int SPI_CS_PIN = 9;
MCP_CAN CAN(SPI_CS_PIN);                                    // Set CS pin
#define PID_ENGIN_PRM       0x0C
#define PID_VEHICLE_SPEED   0x0D
#define PID_COOLANT_TEMP    0x05
#define CAN_ID_PID          0x7DF
unsigned char PID_INPUT;
unsigned char getPid    = 0;
void set_mask_filt()
     * set mask, set both the mask to 0x3ff
    CAN.init_Mask(0, 0, 0x7FC);
    CAN.init_Mask(1, 0, 0x7FC);
     * set filter, we can receive id from 0x04 ~ 0x09
    CAN.init_Filt(0, 0, 0x7E8);
    CAN.init_Filt(1, 0, 0x7E8);
    CAN.init_Filt(2, 0, 0x7E8);
    CAN.init_Filt(3, 0, 0x7E8);
    CAN.init_Filt(4, 0, 0x7E8);
    CAN.init_Filt(5, 0, 0x7E8);
void sendPid(unsigned char __pid)
    unsigned char tmp[8] = {0x02, 0x01, __pid, 0, 0, 0, 0, 0};
    Serial.print("SEND PID: 0x");
    Serial.println(__pid, HEX);
    CAN.sendMsgBuf(CAN_ID_PID, 0, 8, tmp);
    while (CAN_OK != CAN.begin(CAN_500KBPS))    // init can bus : baudrate = 500k
        Serial.println("CAN BUS Shield init fail");
        Serial.println(" Init CAN BUS Shield again");
        delay(100);
    Serial.println("CAN BUS Shield init ok!");
    set_mask_filt();
    taskCanRecv();
    taskDbg();
    if(getPid)          // GET A PID
        getPid = 0;
        sendPid(PID_INPUT);
        PID_INPUT = 0;
void taskCanRecv()
    unsigned char len = 0;
    unsigned char buf[8];
    if(CAN_MSGAVAIL == CAN.checkReceive())                   // check if get data
        CAN.readMsgBuf(&len, buf);    // read data,  len: data length, buf: data buf
        Serial.println("\r\n------------------------------------------------------------------");
        Serial.print("Get Data From id: ");
        Serial.println(CAN.getCanId(), HEX);
        for(int i = 0; i<len; i++)    // print the data
            Serial.print("0x");
            Serial.print(buf[i], HEX);
            Serial.print("\t");
void taskDbg()
        char c = Serial.read();
        if(c>='0' && c<='9')
            PID_INPUT *= 0x10;
            PID_INPUT += c-'0';
        else if(c>='A' && c<='F')
            PID_INPUT *= 0x10;
            PID_INPUT += 10+c-'A';
        else if(c>='a' && c<='f')
            PID_INPUT *= 0x10;
            PID_INPUT += 10+c-'a';
        else if(c == '\n')      // END
            getPid = 1;
No data is ever retrieved.
I’m lost on how i can get the data i want to spit out. Any tips or help is appreciated thanks!
