Now im not quite understanding
Is there any chance you could show me how i would implement this in my current code?
A bit of background probably helps,
Basically im trying to create a Bench testing module so i can plug in a electronic gear selector module from a car so I can function test them on the bench. Push the park button and it comes out of park into N, push stick forward one click it goes into R, pull it back one click it goes into N, pull it back another click it goes into D etc etc
The original coding came from someone who connected up a BMW gear shifter to a racing sim. I thought it would be a base to start.
but im new to this so i could be very wrong
#include <SPI.h>
const uint8_t crc8_lut[] = {
0x00, 0x1d, 0x3a, 0x27, 0x74, 0x69, 0x4e, 0x53, 0xe8, 0xf5, 0xd2, 0xcf,
0x9c, 0x81, 0xa6, 0xbb, 0xcd, 0xd0, 0xf7, 0xea, 0xb9, 0xa4, 0x83, 0x9e,
0x25, 0x38, 0x1f, 0x02, 0x51, 0x4c, 0x6b, 0x76, 0x87, 0x9a, 0xbd, 0xa0,
0xf3, 0xee, 0xc9, 0xd4, 0x6f, 0x72, 0x55, 0x48, 0x1b, 0x06, 0x21, 0x3c,
0x4a, 0x57, 0x70, 0x6d, 0x3e, 0x23, 0x04, 0x19, 0xa2, 0xbf, 0x98, 0x85,
0xd6, 0xcb, 0xec, 0xf1, 0x13, 0x0e, 0x29, 0x34, 0x67, 0x7a, 0x5d, 0x40,
0xfb, 0xe6, 0xc1, 0xdc, 0x8f, 0x92, 0xb5, 0xa8, 0xde, 0xc3, 0xe4, 0xf9,
0xaa, 0xb7, 0x90, 0x8d, 0x36, 0x2b, 0x0c, 0x11, 0x42, 0x5f, 0x78, 0x65,
0x94, 0x89, 0xae, 0xb3, 0xe0, 0xfd, 0xda, 0xc7, 0x7c, 0x61, 0x46, 0x5b,
0x08, 0x15, 0x32, 0x2f, 0x59, 0x44, 0x63, 0x7e, 0x2d, 0x30, 0x17, 0x0a,
0xb1, 0xac, 0x8b, 0x96, 0xc5, 0xd8, 0xff, 0xe2, 0x26, 0x3b, 0x1c, 0x01,
0x52, 0x4f, 0x68, 0x75, 0xce, 0xd3, 0xf4, 0xe9, 0xba, 0xa7, 0x80, 0x9d,
0xeb, 0xf6, 0xd1, 0xcc, 0x9f, 0x82, 0xa5, 0xb8, 0x03, 0x1e, 0x39, 0x24,
0x77, 0x6a, 0x4d, 0x50, 0xa1, 0xbc, 0x9b, 0x86, 0xd5, 0xc8, 0xef, 0xf2,
0x49, 0x54, 0x73, 0x6e, 0x3d, 0x20, 0x07, 0x1a, 0x6c, 0x71, 0x56, 0x4b,
0x18, 0x05, 0x22, 0x3f, 0x84, 0x99, 0xbe, 0xa3, 0xf0, 0xed, 0xca, 0xd7,
0x35, 0x28, 0x0f, 0x12, 0x41, 0x5c, 0x7b, 0x66, 0xdd, 0xc0, 0xe7, 0xfa,
0xa9, 0xb4, 0x93, 0x8e, 0xf8, 0xe5, 0xc2, 0xdf, 0x8c, 0x91, 0xb6, 0xab,
0x10, 0x0d, 0x2a, 0x37, 0x64, 0x79, 0x5e, 0x43, 0xb2, 0xaf, 0x88, 0x95,
0xc6, 0xdb, 0xfc, 0xe1, 0x5a, 0x47, 0x60, 0x7d, 0x2e, 0x33, 0x14, 0x09,
0x7f, 0x62, 0x45, 0x58, 0x0b, 0x16, 0x31, 0x2c, 0x97, 0x8a, 0xad, 0xb0,
0xe3, 0xfe, 0xd9, 0xc4
#define CAN_2515
// #define CAN_2518FD
// Set SPI CS Pin according to your hardware
#if defined(SEEED_WIO_TERMINAL) && defined(CAN_2518FD)
// For Wio Terminal w/ MCP2518FD RPi Hat:
// Channel 0 SPI_CS Pin: BCM 8
// Channel 1 SPI_CS Pin: BCM 7
// Interupt Pin: BCM25
const int SPI_CS_PIN = BCM8;
const int CAN_INT_PIN = BCM25;
#else
// For Arduino MCP2515 Hat:
// the cs pin of the version after v1.1 is default to D9
// v0.9b and v1.0 is default D10
const int SPI_CS_PIN = 9;
const int CAN_INT_PIN = 2;
#endif
#ifdef CAN_2518FD
#include "mcp2518fd_can.h"
mcp2518fd CAN(SPI_CS_PIN); // Set CS pin
#endif
#ifdef CAN_2515
#include "mcp2515_can.h"
mcp2515_can CAN(SPI_CS_PIN); // Set CS pin
#endif
#define CAN_ID_PID 0x401
bool shifter_init_test_done = false;
bool shifter_released = true;
bool parking_button_released = true;
char msgString[128];
char lever_position_code[128];
char parking_position_code[128];
uint8_t status_counter = 0;
// CAN message
long unsigned int rxId;
unsigned char len = 0;
unsigned char rxBuf[8];
// Shifter status codes for GWS
byte shifter_status_park = 0x00;
byte shifter_status_reverse = 0x00;
byte shifter_status_neutral = 0x00;
byte shifter_status_drive = 0x00;
byte shifter_status_manual = 0x00;
// Lever position/movement codes
String shifter_centred = "0x00";
String shifter_middle_move_down1 = "0x00";
String shifter_middle_move_down2 = "0x00";
String shifter_middle_move_up1 = "0x00";
String shifter_middle_move_up2 = "0x00";
String shifter_park_select = "0x00";
String shifter_manual_select = "0x00";
// Shifter pattern and entry shifter position/gear
const byte shifter_schema[5] = { shifter_status_park, shifter_status_reverse, shifter_status_neutral,
shifter_status_drive, shifter_status_manual,};
uint8_t shifter_schema_position = 1;
bool shifter_mode_auto = true;
byte shifter_status_initial = shifter_status_park;
byte shifter_status_current = shifter_status_initial;
uint8_t crc8(uint8_t crc, uint8_t const *buf, uint32_t len) {
for (uint32_t i = 0; i < len; i++) {
uint8_t data = buf[i] ^ crc;
crc = crc8_lut[data] ^ (crc << 8);
return crc ^ 0x00;
//void turnBacklight() {
// 0x202 code is backlight turning code
//byte payload[5] = { 0xFF, 0xFF, 0x00 };
//CAN.sendMsgBuf(0x000, 0, 4, payload);
void setShifterStatus(byte status_code){
uint8_t buf[] = { 0x00, 0x00, status_counter, 0x00 };
uint8_t crc = crc8(0, buf, 4);
byte payload[5] = { 0x00, 0x00, status_counter, crc };
CAN.sendMsgBuf(0x401, 0, 4, payload);
delay(9);
status_counter++;
if ((status_counter)) status_counter++;
SERIAL_PORT_MONITOR.begin(115200);
while (!Serial) {};
while (CAN_OK != CAN.begin(CAN_500KBPS)) { // init can bus : baudrate = 500k
SERIAL_PORT_MONITOR.println("CAN init fail, retry...");
delay(100);
SERIAL_PORT_MONITOR.println("CAN init ok!");
//turnBacklight();
// delay(100);
unsigned char buf[8];
if (CAN_MSGAVAIL == CAN.checkReceive()) { // check if data coming
// Read CAN message
CAN.readMsgBuf(&len, buf); // read data, len: data length, buf: data buf
sprintf(lever_position_code, "0x%.2X", rxBuf[2]);
sprintf(parking_position_code, "0x%.2X", rxBuf[3]);
unsigned long canId = CAN.getCanId();
SERIAL_PORT_MONITOR.println("-----------------------------");
SERIAL_PORT_MONITOR.print("Get data from ID: 0x");
SERIAL_PORT_MONITOR.println(canId, HEX);
for (int i = 0; i < len; i++) { // print the data
SERIAL_PORT_MONITOR.print(buf[i], HEX);
SERIAL_PORT_MONITOR.print("\t");
SERIAL_PORT_MONITOR.println();
// Set and update Shifter status continously
setShifterStatus(shifter_status_current);
// REPEATING 0X202 FOR DIAGNOSTICS
//delay(30);
// END FILE
