I'm trying to implement a CAN bus for my universities Formula Student car. I am using a Teensy 4.1 as my microcontroller to read the CAN messages and display them on an Adafruit HX8357 display.
To complete the CAN interface for the Teensy i'm using an ISO1050 isolated CAN transceiver (see link below) which connects directly to CAN_H and CAN_L of the CAN bus, and CRX3 and CTX3 of the Teensy.
The CAN data is coming from a PM100DX inverter, which already has a CAN node built into it. (See CAN protocol documentation attached below).
All I am trying to do initially is get this data displayed onto the serial monitor and then its a small step from there to get it displayed onto the screen. I am using the FlexCAN_T4 library to program the Teensy (in Arduino IDE of course) but nothing is happening.
I will point out that i'm using a PCAN USB to monitor the traffic on the bus and there is definitely data on the CAN_H and CAN_L wires which go into the transceiver.
Here is my code thus far:
#include <SPI.h>
#include <Adafruit_GFX.h>
#include <Adafruit_HX8357.h>
#include <FlexCAN_T4.h>
#define TFT_CS 10
#define TFT_DC 9
#define TFT_RST 8
#define CRX3 30
#define CTX3 31
unsigned int motor_data;
Adafruit_HX8357 tft = Adafruit_HX8357(TFT_CS, TFT_DC, TFT_RST);
FlexCAN_T4<CAN1, RX_SIZE_256, TX_SIZE_16> can;
delay(3000);
Serial.println("Code Debug");
Serial.println(" ");
pinMode(CRX3, INPUT);
pinMode(CTX3, OUTPUT);
//Initialise the screen
tft.begin();
tft.setRotation(1);
firstScreen();
motor_speed();
//Initialise the CAN bus
can.begin();
can.setBaudRate(250000);
can.enableFIFO();
CAN_message_t msg;
while (can.read(msg)) {
Serial.print("ID: ");
Serial.print(msg.id, HEX);
Serial.print(" Data: ");
for (int i = 0; i < msg.len; i++) {
Serial.print(msg.buf[i], HEX);
Serial.print(" ");
void firstScreen() {
Serial.println("You are on the first screen");
//Backround
tft.fillScreen(HX8357_BLACK);
//Outer Borders
tft.drawFastHLine(0, 0, 480, HX8357_WHITE); //Top Border
tft.drawFastHLine(1, 319, 480, HX8357_WHITE); //Bottom Border
tft.drawFastVLine(479, 0, 319, HX8357_WHITE); //Left Border
tft.drawFastVLine(0, 0, 319, HX8357_WHITE); //Right Border
//Inner Borders
tft.drawFastVLine(240, 0, 320, HX8357_WHITE); //Down the middle
tft.drawFastHLine(0, 30, 480, HX8357_WHITE); //Top Border - Horizontal
tft.drawFastHLine(0, 155, 240, HX8357_WHITE); //Range Intersect
tft.drawFastHLine(0, 295, 240, HX8357_WHITE); //Battery Level Intersect
tft.drawFastHLine(240, 200, 240, HX8357_WHITE); //Speed Intersect
tft.drawFastVLine(360, 200, 120, HX8357_WHITE); //Torque Intersect
//Titles
tft.setCursor(100, 5);
tft.setTextColor(HX8357_WHITE);
tft.setTextSize(3);
tft.println("BMS");
tft.setCursor(320, 5);
tft.setTextSize(3);
tft.println("MOTOR");
////BMS////
//Range
tft.setCursor(90, 80);
tft.setTextSize(2);
tft.println("Range");
tft.setCursor(70, 110);
tft.setTextSize(2);
tft.println("-- miles");
for (int p = 2000; p < 4000; p++) {
int j, j2, i, i2;
j = 100 * (sin(PI * p / 2000));
i = 100 * (cos(PI * p / 2000));
j2 = 90 * (sin(PI * p / 2000));
i2 = 90 * (cos(PI * p / 2000));
tft.drawLine(i2 + 120, j2 + 140, i + 120, j + 140, HX8357_GREEN);
//Battery Temperature
tft.setCursor(83, 225);
tft.setTextSize(2);
tft.println("BatTemp");
tft.setCursor(80, 255);
tft.setTextSize(2);
tft.println("-- degC");
//Outer Gauge
for (int p = 2000; p < 2666; p++) {
int j, j2, i, i2;
tft.drawLine(i2 + 120, j2 + 270, i + 120, j + 270, HX8357_GREEN);
for (int p = 2666; p < 3332; p++) {
int j, j2, i, i2;
tft.drawLine(i2 + 120, j2 + 270, i + 120, j + 270, HX8357_YELLOW);
for (int p = 3332; p < 4000; p++) {
int j, j2, i, i2;
tft.drawLine(i2 + 120, j2 + 270, i + 120, j + 270, HX8357_RED);
//Inner Gauge
for (int p = 2000; p < 300 * 2000 / 180; p++) {
int j, j2, i, i2;
j = 85 * (sin(PI * p / 2000));
i = 85 * (cos(PI * p / 2000));
j2 = 75 * (sin(PI * p / 2000));
i2 = 75 * (cos(PI * p / 2000));
tft.drawLine(i2 + 120, j2 + 270, i + 120, j + 270, HX8357_WHITE);
//Battery Charge
tft.fillRect(6, 300, 43, 15, HX8357_GREEN);
tft.fillRect(53, 300, 43, 15, HX8357_GREEN);
tft.fillRect(100, 300, 43, 15, HX8357_GREEN);
tft.fillRect(147, 300, 43, 15, HX8357_GREEN);
tft.fillRect(194, 300, 43, 15, HX8357_GREEN);
////Motor////
// //Speed
// tft.setCursor(320, 50);
// tft.setTextColor(HX8357_WHITE);
// tft.setTextSize(3);
// tft.println("Speed");
// tft.setCursor(300, 110);
// tft.setTextSize(5);
// tft.println(motor_data);
// tft.setCursor(350, 110);
// tft.println(" mph");
//Torque
tft.setCursor(265, 220);
tft.setTextSize(2);
tft.println("Torque");
tft.setCursor(260, 270);
tft.setTextSize(3);
tft.println("-- Nm");
void motor_speed() {
//Speed
tft.setTextSize(3);
tft.setTextSize(5);
tft.setTextSize(5);
Apologies for any glaringly obvious mistake, I am extremely new to the CAN protocol and have much to learn in regards to my programming skills as well. Would appreciate any help. Thanks.
Links:
https://app.box.com/s/vf9259qlaadhzxqiqrt5cco8xpsn84hk/file/27334613044
