i made some kind of a sketch and i struggle with few things.
I managed to get RPM and coolant temperature to RealDash.
With this sketch these works sometimes and sometimes not, usually coolant temperature is missing.
Anyway, i had connector for ABS unit disconnected and RPM seemed to work fine, no lag.
When i connect it RPM needle or bar indicator has a lag. Maybe that error is in the code, or can Arduino with CAN-shield be too slow?
Smoothing fucntion does not help in RealDash
With CAN-receiving code RPM CAN-messages come very rarely in serialmonitor when ABS unit is connected.
Almost all messages come from ABS then randomly and rarely something else to serial monitor.
If ABS not connected then for example RPM messages come all the time and gauge works without lags.
#include <mcp_can.h>
#include <SPI.h>
long unsigned int rxId;
unsigned char len = 0;
unsigned char rxBuf[8];
char msgString[128]; // Array to store serial string
#define CAN0_INT 2 // Set INT to pin 2
MCP_CAN CAN0(9); // Set CS to pin 9
int rpm;
int coolant;
bool glow;
bool engineMIL;
// Initialize MCP2515 running at 16MHz with a baudrate of 500kb/s and the masks and filters disabled.
if(CAN0.begin(MCP_ANY, CAN_500KBPS, MCP_16MHZ) == CAN_OK)
Serial.println("MCP2515 Initialized Successfully!");
Serial.println("Error Initializing MCP2515...");
CAN0.setMode(MCP_NORMAL); // Set operation mode to normal so the MCP2515 sends acks to received data.
pinMode(CAN0_INT, INPUT); // Configuring pin for /INT input
if(!digitalRead(CAN0_INT)) // If CAN0_INT pin is low, read receive buffer
CAN0.readMsgBuf(&rxId, &len, rxBuf); // Read data: len = data length, buf = data byte(s)
sprintf(msgString, "Standard ID: 0x%.3lX DLC: %1d Data:", rxId, len);
for (byte i = 0; i < len; i++) {
sprintf(msgString, " 0x%.2X", rxBuf[i]);
// Serial.print(msgString);
if (rxId == 0x280) {
uint16_t rawRPM = (uint16_t)rxBuf[2] << 8;
rawRPM |= rxBuf[3];
rpm = rawRPM/4;
else if (rxId == 0x288) {
uint8_t rawCOOLANT = (uint8_t)rxBuf[1];
coolant = rawCOOLANT * 0,75-48;
else if (rxId == 0x488) {
glow = bitRead(rxBuf[1],7);
engineMIL = bitRead(rxBuf[1],4);
SendCANFramesToSerial();
void SendCANFramesToSerial()
byte buf[8];
// build & send CAN frames to RealDash.
// a CAN frame payload is always 8 bytes containing data in a manner
// described by the RealDash custom channel description XML file
// build 1st CAN frame, RPM, MAP, CLT, TPS
buf[0] = (0x49);
buf[1] = (0xff);
buf[2] = ((rpm >> 8) & 0xff);
buf[3] = (rpm & 0xff);
buf[4] = (0xff);
buf[5] = (0xff);
buf[6] = (0xff);
buf[7] = (0xff);
// write first CAN frame to serial
SendCANFrameToSerial(3200, buf);
// build 2nd CAN frame, coolant
buf[0] = (0xff);
buf[1] = (coolant & 0xff);
buf[2] = (0xff);
buf[3] = (0xff);
buf[4] = (0xff);
buf[5] = (0xff);
buf[6] = (0xff);
buf[7] = (0xff);
// write 2nd CAN frame to serial
SendCANFrameToSerial(3201, buf);
// build 3rd CAN frame, glow and engineMIL
buf[0] = (0xff);
buf[1] = glow;
buf[2] = engineMIL;
buf[3] = (0xff);
buf[4] = (0xff);
buf[5] = (0xff);
buf[6] = (0xff);
buf[7] = (0xff);
SendCANFrameToSerial(3202, buf);
void SendCANFrameToSerial(unsigned long canFrameId, const byte* frameData)
// the 4 byte identifier at the beginning of each CAN frame
// this is required for RealDash to 'catch-up' on ongoing stream of CAN frames
const unsigned long serialBlockTag = 0x11223344;
Serial.write((const byte*)&serialBlockTag, 4);
// the CAN frame id number
Serial.write((const byte*)&canFrameId, 4);
// CAN frame payload
Serial.write(frameData, 8);
