Which function to call to communicate over CAN on the portenta H7 and the breakout board?
read
#include <Arduino_CAN.h>
void setup(){
while (!Serial) { }
if (!CAN.begin(CanBitRate::BR_250k)) {
Serial.println("CAN.begin(...) failed.");
for (;;) {}
void loop(){
if (CAN.available()) {
CanMsg const msg = CAN.read();
Serial.println(msg);
write
static uint32_t const CAN_ID = 0x20;
static uint32_t msg_cnt = 0;
void setup(){
while (!Serial) { }
for (;;) {}
void loop(){
/* Assemble a CAN message with the format of
* 0xCA 0xFE 0x00 0x00 [4 byte message counter]
uint8_t const msg_data[] = {0xCA,0xFE,0,0,0,0,0,0};
memcpy((void *)(msg_data + 4), &msg_cnt, sizeof(msg_cnt));
CanMsg msg(CanStandardId(CAN_ID), sizeof(msg_data), msg_data);
/* Transmit the CAN message, capture and display an
* error core in case of failure.
if (int const rc = CAN.write(msg); rc <= 0)
Serial.print ("CAN.write(...) failed with error code ");
Serial.println(rc);
for (;;) { }
/* Increase the message counter. */
msg_cnt++;
/* Only send one message per second. */
