I am using a timer within Due to generate programmable clocks for a CPLD.
The highest clock frequency achieved up to now is 21 MHz. But I'd like to have 42 Mhz.
The highest available clock frequency a timer can get is TIMER_CLOCK1 which is MCK/2=42 MHz. Is it possible to feed this frequency to an output pin of the Due?
Yes, it's possible to get a 42MHz signal using the Due's PWM controller.
Here's some example code that outputs 42MHz on D9:
// Output a 42MHz PWM waveform on pin D9 (PWML4)
PMC->PMC_PCER1 |= PMC_PCER1_PID36; // Enable the PWM Controller
PIOC->PIO_ABSR |= PIO_ABSR_P21; // Set PWM pin perhipheral type A or B, in this case B
PIOC->PIO_PDR |= PIO_PDR_P21; // Set PWM pin to an output
PWM->PWM_CLK = PWM_CLK_PREA(0) | PWM_CLK_DIVA(1); // Set the PWM clock rate to 84MHz (84MHz/1=84MHz)
PWM->PWM_CH_NUM[4].PWM_CMR = PWM_CMR_CPRE_CLKA; // Enable single slope PWM and set the clock source as CLKA
PWM->PWM_CH_NUM[4].PWM_CPRD = 2; // Set the PWM frequency 84MHz/48MHz = 2
PWM->PWM_CH_NUM[4].PWM_CDTY = 1; // Set the PWM duty cycle
PWM->PWM_ENA = PWM_ENA_CHID4; // Enable the PWM channel 4
void loop() {}
