Can EEPROM be written via ISP without overwriting/impacting flash
Is it possible to use ISP to read and write parts of (or whole of) EEPROM, without touching the program stored in flash, or any of the fuse-bits etc. ? Should one use avrdude for this ? If so, are there any special precautions ? Or, if there is/are specific s/w tools ?
Is this the right way to store device specific configuration and other field-debugging data ? And ISP the right (or at least, acceptable) way to access this data ?
thanks, F
falcon74: Is it possible to use ISP to read and write parts of (or whole of) EEPROM, without touching the program stored in flash, or any of the fuse-bits etc. ?
Yes, AVRDUDE has that capablity, however such AVRDUDE commands are not supported via the arduino IDE but rather using command line instructions.
AVRDUDE in the guy to use.
Well EEPROM is avalible for such uses, it's totally under user control. There are other ways to read and write to EEPROM memory within a sketch and then send or recieve the values to or from the USB serial port, or I2C bus or SPI bus. thanks, F
Two...
  1. Some boards have the fuses set so the EEPROM is erased when programming the Flash.
  2. The 328 family bootloaders (Uno / optiboot, Duemilanove) do not support accessing the EEPROM. If you are using an ISP (like an Uno runing the ArduinoISP sketch) then you will not be affected.
A note of interest: The toolset is capable of automatically generating an EEPROM image. The Arduino IDE does not support the feature so you will have to perform the last two steps from the command-line.
Thanks @retrolefy and @CodingBadly.
@CodingBadly, when you say "328 family bootloaders... do not support accessing the EEPROM", do you mean to highlight tha t as a current limitation of those bootloaders, and something to keep in mind if I plan to do anything with the bootloader code ? Does it mean that if a Duemilanove or Uno is used as the target (not as the "Arduino-as-ISP board"), directly connected to PC via Serial-over-USB, I can't directly write to EEPROM ?
Well, I am interested in both things, i.e. -
  1. Use Arduino-as-ISP (or even willing to invest in that nice Pololu USB ISP), to program the target ATtiny85, and also write/read information on it's EEPROM from the PC. a. Is this possible ? b. Can I use avrdude command-line version using Arduino-as-ISP to read / write EEPROM ? Or I need a dedicated ISP ?
  2. Somehow (not sure how), target Arduino board (Uno / Duemilanove)'s EEPROM, to be read / written from PC. a. Is this possible ? b. Can I use avrdude command-line version for this ? I guess not, because bootloader doesn't support it ?
Hopefully, I could reset the fuse-bits (if set) that erase EEPROM when programming the flash, using avrdude commandline, and either a standalone ISP or Arduino-as-ISP.
falcon74: @CodingBadly, when you say "328 family bootloaders... do not support accessing the EEPROM", do you mean to highlight that as a current limitation of those bootloaders, and something to keep in mind if I plan to do anything with the bootloader code ?
Mostly. "...something to keep in mind if I plan to access the EEPROM on my Uno" is a more accurate
Exactly.
Yes.
A dedicated ISP is not required (but is often handy ;)).
  1. Somehow (not sure how), target Arduino board (Uno / Duemilanove)'s EEPROM, to be read / written from PC. a. Is this possible ?
It is if you put an ISP in the middle. A second board running ArduinoISP will work.
The Arduinos have a six-pin ISP connector just for that sort of work or you can connect jumpers to the correct pins.
Yes. The commands are almost identical. The only thing that changes is the kind of memory (Flash vs EEPROM vs Signature).
That is only an issue if you try to access EEPROM on a board connect directly to the computer.
Essentially, the Arduino bootloaders are like a carry-along ISP. Wherever the processor goes, an ISP (in the form of a bootloader) goes with it. The bootloader in question is very basic; it lacks EEPROM support. Support could be added but most people do not need it and EEPROM support would make the bootloader considerably larger.
You can. But I suggest first checking if it is an issue for the target board. All the new processors I've purchased have "erase EEPROM" set (the fuses have to be changed to "preserve EEPROM").
If you are using the Tiny Core and ever Burn Bootloader, "preserve EEPROM" is set.
Thanks a ton, @CodingBadly. All questions clearly answered.
The fuse determines whether EEPROM is erased as part of a ISP flash erase cycle. You will typically want to dsiable this fuse for designs that need to preserve EEPROM content. When programming through a bootloader however, this fuse is not used and so not relevant.
  1. The 328 family bootloaders (Uno / optiboot, Duemilanove) do not support accessing the EEPROM. If you are using an ISP (like an Uno runing the ArduinoISP sketch) then you will not be affected.
The 168/328 bootloader supplied with 022 supports reading/writing EEPROM (as used by Duemillanove) and I think you will find that EEPROM read/write is supported by a number of compatible boards as well (Uno/Optiboot being the exception). There is also a handy interactive mode available with avrdude that will enable you to read/write individuall EEPROM cells (through ISP or bootloader).
Another option is to write and upload a simple run-once sketch to initialize EEPROM as per your requirements.
You could also test EEPROM cells for the default 0xFF value (uninitialized) on startup (such as in Setup). This would allow you to determine whether to procede with defaults (stop reading from EEPROM) or use the initialized EEPROM values. Other parts of your sketch may then update EEPROM and so the next time you cycle power, the EEPROM cell you check against will have a value different from 0xFF suggesting EEPROM content can be trusted.
Yet another possibility is to add support in your sketch for reading configuration information from USB/Serial and preserve this in EEPROM.
The 168/328 bootloader supplied with 022 supports reading/writing EEPROM...
Yikes! Sorry about that.
[quote author=Coding Badly link=topic=91073.msg683671#msg683671 date=1328764646] A note of interest: The toolset is capable of automatically generating an EEPROM image. The Arduino IDE does not support the feature so you will have to perform the last two steps from the command-line. [/quote] Could you expand on this please?
What is automatically generated by the toolset and where does it get its input and in what format?
Iain
http://www.google.com/search?q=EEMEM+avrdude+eep+site%3Aarduino.cc
Mostly about modifying the IDE and bootloader but should have enough information to get it working from the command-line... http://arduino.cc/forum/index.php/topic,22784.0.html
Just referencing; no uploading... http://arduino.cc/forum/index.php/topic,66206.msg499437.html#msg499437
I vaguely recall someone posting step-by-step instructions but I cannot find them. Hopefully the keywords in the Google query will get you on the right path.
My bad! The Arduino IDE automatically creates the EEP file. You just need to find it (in TEMP) and upload it using avrdude.
An EEP file. It has the same format as a HEX file but is intended to be uploaded to EEPROM instead of Flash. The "input" is from all variables marked with "EEMEM".
[quote author=Coding Badly link=topic=91073.msg695411#msg695411 date=1329556022]
[/quote] Ah! EEMEM. Didn't know about that. I guess it's like PROGMEM (which I did know about) but for EEPROM.
Thanks very much.
Iain
