Can em frequencies be filtered with arduino?
Hello, I needed the code to filter an electromagnetic wave in arduino nano.
Let me explain a little; For low frequencies like 30hz-100hz and frequencies with millivolt amplitude (em wave, not sound) it is quite difficult to apply analog filtering. In some places there is a statement that this process can be done digitally on the arduino.
Can a code be created for this?
I want the signal to pass through the shiming trigger and enter the arduino as a digital signal. Is it possible to filter in this case?
Could someone familiar with this topic help?
Thanks.
100hz is manageable, the non optimized analogRead() function takes about 100 microseconds to run.
your signal will likely require amplification before being fed into the arduino
What might that be?
Sorry, it is schmitt trigger :sweat_smile:
Thanks for the response.
I'm going to raise the amplitude. There was confusion in the statement. After the Schmitt trigger, a digital input is already provided to the arduino as 5v.
Let me expand the frequency range a little more;
The band between 0 hz - 600 hz, the interval between 50 hz - 85 hz will be stopped.
0hz - 45hz pass,
49 hz - 85 hz: stop,
85 hz - 600 hz: pass,
600 hz - continuing frequencies: stop
it is an integrated. converts the analog signal to digital.
You will want to filter an analog signal, or a digitized analog signal, not a digital signal. Look up bandpass filter.
600Hz is well below the maximum ~9600Hz analogRead(), so it's possible.
You'd need to apply a digital filter to your timeseries though.
Here's an example: Arduino Filters: FIRNotch.ino
I understand, but in the end, we pass an irregular signal through the schmitt trigger integrated, convert it to digital and then send it to the arduino.
Use of the Schmidt trigger introduces frequency artifacts into the signal.
They have published code for this in several places. However, I don't know if it will work in my target frequency range.
<600 Hz isn't terribly high speed, but I've not experimented with it.
It would improve the quality of your feedback if you can direct us to those several places. What you've told us so far, doesn't really explain what's going on.
I don't understand, can you explain a little more? Even if we do not use trigger, I know that this signal is still converted to digital in the arduino analog input.
The Schmidt trigger converts an analog input signal to a series of purely digital (1/0) rectangular pulses. That is not what you want.
To remove low frequencies from an analog signal, use either analog low pass filter circuitry, or use the analog to digital converter to create a time series (of integers), and a low pass digital filter to remove the low frequency components from that time series.
That's what I want you to do.
For example, a similar issue is mentioned here, but it is not explained whether there is a solution or not.
Explain YOUR project. This is not the place to discuss someone else's project.
my friend, I explained my project above. a friend suggested the notch filter code. I will try this. The remainder is a low-pass filter code to use at the band ends, and the other is a normal band-pass filter code. I need these.
It is unnecessary to write the same frequencies again and again.
Forget the Schmidt trigger. Good luck with your project!
