Can Functions Free up Memory Space?
I wrote a long and inefficient code that takes up 97% of the storage stage on my Arduino nano and 34% of the dynamic memory. Now that my code works, I'm trying to make my code more efficient to save on memory space. There are a number of sections of my code that I could replace with functions, but after attempting to replace some of the code with functions, it seemed like I didn't save any space.
Are functions just to make programming easier so you don't have to retype the same part over and over, or will replacing sections of code will a function call actually save space? I'm just not sure from a compiler perspective, if replacing code with a function call save memory. Thanks in advance!
For example, I wrote 80 functions. One such function (below) blinks LED's and moves servo motors to music, but this function alone takes up ~6% of my memory space. I could write a function that just turns the lights on "DarkTurquoise" and call that function three times instead of writing three for loops.
void Scene49()///////////////////////////////WILL WILL ROCK YOU
  int loop1 = 0;
  INITIALIZE_VARIABLES();
  startSoundInBackground(48);
  delay(800);
  while (loop1 < 4)
    for (int i = 0; i < NUM_LEDS; ++i)              //ON
      leds[i] = CRGB::DarkTurquoise;
    FastLED.show();
    delay(150);
    FastLED.clear (); //TURN LED's off            //OFF
    FastLED.show();
    delay(150);
    FastLED.show();
    delay(150);
    FastLED.show();
    delay(100);
    FastLED.show();
    delay(400);
    FastLED.clear (); //TURN LED's off          /OFF
    FastLED.show();
    delay(510);
      leds[i] = CRGB::Gold;
    FastLED.show();
    delay(150);
    FastLED.show();
    delay(150);
    FastLED.show();
    delay(150);
    FastLED.show();
    delay(100);
    FastLED.show();
    delay(400);
    FastLED.show();
    delay(510);
      leds[i] = CRGB::Lime;
    FastLED.show();
    delay(150);
    FastLED.show();
    delay(150);
    FastLED.show();
    delay(150);
    FastLED.show();
    delay(100);
    FastLED.show();
    delay(400);
    FastLED.show();
    delay(510);
      leds[i] = CRGB::Magenta;
    FastLED.show();
    delay(150);
    FastLED.show();
    delay(150);
    FastLED.show();
    delay(150);
    FastLED.show();
    delay(100);
    FastLED.show();
    delay(400);
    FastLED.show();
    delay(510);
    loop1++;
  FastLED.show();
  delay(150);
  FastLED.show();
  delay(150);
  FastLED.show();
  delay(150);
  FastLED.show();
  delay(100);
  FastLED.show();
  delay(400);
  FastLED.show();
  delay(510);
  FastLED.show();
  delay(150);
  FastLED.show();
  delay(150);
  FastLED.show();
  delay(150);
  FastLED.show();
  delay(100);
  FastLED.show();
  delay(400);
  FastLED.show();
  delay(510);
  FastLED.show();
  delay(150);
  FastLED.show();
  delay(150);
  FastLED.show();
  delay(150);
  FastLED.show();
  delay(100);
  FastLED.show();
  delay(400);
  FastLED.show();
  SWITCH_FAST();
  delay(5000);
  FastLED.show();
No. Functions also replace copy/pasting copies of code.
Enough hand-waving. Post the code that you have questions about.
Functions are best used to make programs easier to understand (to others, or to you in six months time), not necessarily to make programming easier.
A function will only save space if it replaces a lot of repetitive code.
PaulS:
I updated my original post with some my my example code. New to coding so I'm sure that it's pretty inefficient, But I'm trying to learn how to make it more efficient.
  FastLED.show();
  delay(400);
  FastLED.show();
Variable colour, variable delay, repeated.
Looks like an ideal function candidate.
Something along these lines
void displayLEDS( CRGB newColor, showDelay, blankDelay )
      leds[i] = CRGB::newColor;
    FastLED.show();
    delay(showDelay);
    FastLED.show();
    delay(blankDelay );
If you want to save more space (and as explained above, functions in your example will do so), inspect your code to see which 'int' variables can be 'byte' (i.e. if they never have a value more than 255), and get rid of any floating-point arithmetic if possible. For example, temperatures are usually expressed with one decimal (20.4 degrees) for humans, but your code can work with integer variables ten times as big (204) and just convert when they are displayed.
