can i access router configuration page?
hi everyone
i tried telnetclient to connect to router but it didnt work for some reason, now i want to try to connect to it form the http
so basically i want the arduino to connect to the ip address if the router, send the username and the password to login, and reach the main page of the router configuration.
can i do that? and how?
i tried the webclient and changed the ip to the router ip but it didnt work, cant connect
write a PC program for it and if it works, port it to arduino. I recommend Java with Eclipse IDE
What router? What telnetclient code? What HTTP client code? But most importantly: Why?
Pieter
What were you telnetting from? Before you write any code on anything check you can browse and telnet to the router from a PC. Then try doing it using a program on the PC as @Juray suggested, then use the Arduino. But as @PieterP asked why?
