Can I ask I'm new on Arduino
Arduino: 1.8.16 (Windows 10), Board: "NodeMCU 1.0 (ESP-12E Module), 80 MHz, Flash, Disabled (new aborts on oom), Disabled, All SSL ciphers (most compatible), 32KB cache + 32KB IRAM (balanced), Use pgm_read macros for IRAM/PROGMEM, 4MB (FS:2MB OTA:~1019KB), 2, v2 Lower Memory, Disabled, None, Only Sketch, 115200"
E:\MS ABE\ADVANCE IRRIGATION AND DRAINAGE\Ad_Irr\Ad_Irr.ino: In function 'void sendSensor()':
Ad_Irr:38:10: error: expected primary-expression before '.' token
38 | Blynk_h.virtualWrite(V5, h); //V5 is for Humidity
Ad_Irr:39:10: error: expected primary-expression before '.' token
39 | Blynk_h.virtualWrite(V6, t); //V6 is for Temperature
E:\MS ABE\ADVANCE IRRIGATION AND DRAINAGE\Ad_Irr\Ad_Irr.ino: In function 'void setup()':
Ad_Irr:44:10: error: expected primary-expression before '.' token
44 | Blynk_h.begin(auth, ssid, pass);
Ad_Irr:44:17: error: 'auth' was not declared in this scope; did you mean 'auto'?
  |                 auto
Ad_Irr:50:10: error: expected primary-expression before '.' token
50 | Blynk_h.begin(auth, ssid, pass);
E:\MS ABE\ADVANCE IRRIGATION AND DRAINAGE\Ad_Irr\Ad_Irr.ino: In function 'void sendTemps()':
Ad_Irr:61:8: error: expected primary-expression before '.' token
61 | Blynk_h.virtualWrite(V1, temp);
Ad_Irr:62:8: error: expected primary-expression before '.' token
62 | Blynk_h.virtualWrite(V2,sensor);
E:\MS ABE\ADVANCE IRRIGATION AND DRAINAGE\Ad_Irr\Ad_Irr.ino: In function 'void loop()':
Ad_Irr:67:10: error: expected primary-expression before '.' token
67 | Blynk_h.run();
Ad_Irr:75:3: error: 'initState' was not declared in this scope; did you mean 'initstate'?
75 | initState = 0;
  |   initstate
Ad_Irr:76:10: error: expected primary-expression before '.' token
76 | Blynk_h.notify("Water your plants");
exit status 1
option enabled in File -> Preferences.
I don't see a question.
You should also post your code and a schematic if you have stuff connected to you Arduino.
Did you install the ESP32 core and select the correct board?
@cu3nca sure you can ask but not in the section you posted in. This is about the installation troubleshooting of the system NOT YOUR project.
You post is clearly about your project so I have moved the post to a more appropriate section.
Did you download this code from somewhere? If so, please post a link to that source.
The problem is that the identifier Blynk_h is defined as a macro in the library. Something like this:
#define Blynk_h
You can not also use that same name also as an object name. Pick some other unused name for the identifier.
