Can I change matrix color?
Hi.
I use "LedControl.h" header file now, but I drawing character only red color.
Can I change Matrix color?
I use arduino r3 and max7219 chip
#include "Arduino.h"
#include "LedControl.h"
Now we need a LedControl to work with.
***** These pin numbers will probably not work with your hardware *****
pin 12 is connected to the DataIn
pin 11 is connected to the CLK
pin 10 is connected to LOAD
We have only a single MAX72XX.
LedControl lc = LedControl(8,10,9,1); //DIN, CLK, CS
LedControl lc2 = LedControl(4,6,5,2);
unsigned long delaytime=500;
lc.shutdown(0,false);
lc.clearDisplay(0);
lc2.shutdown(0,false);
lc2.clearDisplay(0);
void setBright(){
lc.setIntensity(1,15);
lc2.setIntensity(2,15);
void writeArduinoOnMatrix() {
byte a[8]={0,0,240,28,18,28,240,0};
byte r[8]={0,0,255,17,41,69,131,0};
byte d[8]={0,0,255,129,66,36,24,0};
byte u[8]={0,62,64,128,128,64,62,0};
byte I[8]={0,0,130,130,254,130,130,0};
byte n[8]={0,254,32,16,8,4,254,0};
byte o[8]={0,0,0,62,65,65,62,0};
for(int i=0; i<8; i++){
lc.setRow(0,i,a*);*
_ lc2.setRow(0,i,r*);_
_
}_
_
delay(delaytime);_
_
for(int i=0; i<8; i++){_
_ lc.setRow(0,i,r);
lc2.setRow(0,i,d);
delay(delaytime);
lc.setRow(0,i,d);
lc2.setRow(0,i,u);
delay(delaytime);
lc.setRow(0,i,u);
lc2.setRow(0,i,I);
delay(delaytime);
lc.setRow(0,i,I);
lc2.setRow(0,i,n);
delay(delaytime);
lc.setRow(0,i,n);
lc2.setRow(0,i,o);
delay(delaytime);
lc.setRow(0,i,o);
lc2.setRow(0,i,0);
delay(delaytime);
lc.setRow(0,i,0);
delay(delaytime);
setBright();
writeArduinoOnMatrix();
}*_
Do you have a RGB matrix?
If not, no you cannot change the color.
Please read the how to use the forum sticky post, edit that first post to use code tags ( the </> icon ) so your code is not mangled. Did you write part of it in italics?
The answer is probably no.
But:-
What hardware have you got and how is it wired?
I ask my store, and they say to me mine can't do this. thank you
