I want to connect a display to my already existing circuit. My problem is that the pins D10 to D13 are already connected. Can I change the pin configuration of the library without problems or not?
Normal:
LCD RS pin to digital pin 12
LCD Enable pin to digital pin 11
LCD D4 pin to digital pin 5
LCD D5 pin to digital pin 4
LCD D6 pin to digital pin 3
LCD D7 pin to digital pin 2
LCD R/W pin to ground
So I have to change pin 11 and 12, to which other pins I can connect them?
You should be able to use any pins available except 0 and 1 as long as you change the parameters when you create an instance of the LCD. Try changing the pin assignments in a simple program first such as the LiquidCrystal Hello World example.
for my LCD's. The reason is because the UNO uses 0 and 1 for the Serial object (as Bob pointed out) and pins 2 and 3 are used for external interrupt service routines. If you don't ISR's, pins 2 and 3 are usable, too.
This cabling keeps free many useful pins like:
pin-0/1 used for Serial debugging
pin-2/3 which can be used for hardware interrupts
pin-10/11/12/13 which are the SPI pins on Atmega328 boards
pin-A4/A5 which are the I2C pins on Atmega328 boards
Of course, LCD cabling could use other pins, including the analog pins A0, A1, A2, ...
This configuration also has the advantage of matching the pin number arrangement of the common lcd button shields, and some sketches can be easily be shuffled around to use either the shield or standard display.
Hi guys, wondering the same thing as I want to put an EF02037 shield on top of my uno, but pin 0 and pin 7 aren't connected from the uno to the EF02037 shield.
My current line of code reads:
LiquidCrystal lcd(12,11,10,9,8,7,6,5,4,3,2);
I also notice I have 11 pins assigned above and you guys are using 6 pins.
See this information on the Liquid Crystal Constructor
You have a complete "constructor" for 8 bit mode with a RW pin. That is very unusual, and most of the displays are run in 4 bit mode with the 6 pin constructor and RW grounded.
My advice would be to use use the 6 pin constructor, and don't use pin 0 or 7, or any of the pins used by the function of the shield.
Thank you cattledog, I have gone to 4 bit data transfer on it and had it working on fine, but when I added another shield ontop (EF02037) and use the same pin connectors it just does this:
Is it possible the EF02037 shield is using some of the same pins?
