Can I connect a toy's speaker output to some USB speakers?
I apologize if this isn't the proper sub-forum.
I have a toy with a little .5W 8 Ohm speaker, it also has a variable resistor to control the volume. Could I safely connect the speaker output to the input of some USB speakers? Basically using the toy's speaker output as a pre-amp?
I'm really not concerned with damaging the USB speakers, I just do not want to damage the toy.
Definitely not USB speakers, you need something with an analog audio input.
what are USB speakers ? More info required regarding toy and "USB speakers"
I guess I should have said, USB powered speakers. The ones I want to test with use a USB port just for 5v power, they have a male 2.5mm or 3.5mm jack that plugs into a pc's speaker out. I wanted to test powering the speakers with 5v, and connecting the toy's speaker output to the audio jack.
Thought I would come here for expert advice though, I do not want to risk damaging the toy.
In that case yes they are just like any other speaker / amplifier combination.
USB generally limited to 500mA, so 2.5W max output.
