Can I connect two Arduinos to send a video signal ?
Hi !
I need some help because, i wants to communicate between 2 arduino cards. One is linked to my labtop and the other is on my robot. But i wants to know how can i communicate between them. I want to fix a serial camera on the robot and receive the video in realtime. Can i use xbee ? something other ? which arduino car i need ? (i would like to use an arduino leonardo, it is possible ?)
thx XD
I supose that i can use a xbee because the serial camera has a 38 400 baud speed (= 38,40 Kbps), and xbee can transmit 250kbps
? is that right ?
What you have said seems feasible and I can say it seems like it should work in theory, but I don't have any experience working with serial video streams or xbee.
If you are simply using the camera to see what is going on you might also look at all-in-one FPV (First Person View) cameras sold to hobbyists. If you look at a site like www.hobbyking.com you will see many models that come with the camera, transmitter, and a receiver. There are also transmitter receiver pairs that send a stream from an existing camera.
It won't be very real time then.
I would look at an existing FPV system as well.
Rob
ok thx,
i am going to use a normal serial camera, because it is more interesting :slight_smile:
