The question is fairly simple.
I want to disconnect the processing of the incoming & outgoing data on the UART from the MIDI object.
quite simply said, outgoing should not be an issue, i can simply send data to the UART, but anything that comes in is processed and the UART rx-buffer is emptied, and if the incoming data is not Midi, i can not get access to it.
As usual a need, needs some explanation. I am transferring Midi thru 2 HC-05 BT modules, but i want the controlling MCU also to be able to access the AT-commands. Switch the enable pin (no prob) and give it a power cycle (also no prob) , send the command, but whatever comes back will be processed as midi, and that i don't want.
Any ideas ?
