Can i feed arduino some voltage trough analog in so it reads it as high or low?
I have problem with program because i need to program servos to go back and forth without delay function and i can't find solution for it so i thought that solution would be capacitor timer over resistor into the arduino so it can read high or low and i can use it without delay. Will that work?
Why can't you use a delay based on the millis() function?
i tried servos behave very weirdly. I would like to see your solution if you can code it fast. I am a beginner, and I used for loops if you can write some code down so i can analyze it and use it, i am like a sponge now i want all the knowledge i can get.
You should be showing us your current sketch.
There is an example called Blink Without Delay in the IDE.
This example demonstrates some ways to use this method:
//Simple BWD BlinkWithoutDelay examples
//Timer variables used
unsigned long currentMillis;
unsigned long pin13Millis;
unsigned long pin12Millis;
unsigned long SwitchMillis;
//if these are not changed in the sketch, they can be const
unsigned long debounceMillis = 50UL;  //50ms
unsigned long ledOnTime      = 500UL; //500ms seconds
byte lastSwitchState = HIGH;
byte buttonState     = HIGH;
//enable/disable flags
boolean flag13 = true;
boolean flag12 = false;
const byte Switch = 2; //pushed = LOW
  digitalWrite(13,LOW);
  pinMode(13, OUTPUT);
  digitalWrite(12,LOW);
  pinMode(12, OUTPUT);
  pinMode(Switch, INPUT_PULLUP); //pushed = LOW
} //  >>>>>>>>>>>>>> E N D  O F  s e t u p ( ) <<<<<<<<<<<<<<<<<
  //save the current time
  currentMillis = millis();
  //Heartbeat LED
  //Toggle LED on and off. Helps show if there is blocking code
  if (flag13 == true && currentMillis - pin13Millis >= ledOnTime)
    pin13Millis = millis();            //re-initialize Timer
    digitalWrite(13,!digitalRead(13)); //toggle LED condition
  if (flag12 == true && currentMillis - pin12Millis >= 5*1000UL)
    //Turn off pin 12
    digitalWrite(12,LOW); //Turn off LED
    flag12 = false;       //disable timing
  //is it time to check the switches?
  if (currentMillis - SwitchMillis >= debounceMillis)
    //code here runs every debounceMillis ms
    SwitchMillis = millis(); //re-initilize Timer
    //go and check the switches
    checkSwitches();
  //put other non-blocking stuff here
} //  >>>>>>>>>>>>>> E N D  O F  l o o p ( ) <<<<<<<<<<<<<<<<<
//                      F U N C T I O N S
//****************** c h e c k S w i t c h e s ( ) *********************
//switches are checked every debounceValue milli seconds
//no minimum switch press time is validated with this code (i.e. No glitch filter)
void checkSwitches()
  //re-usable for all the switches
  boolean thisState;
  //check if this switch has changed state
  thisState = digitalRead(Switch);
  if (thisState != lastSwitchState)
    //update the switch state
    lastSwitchState = thisState;
    //this switch position has changed so do some stuff
    //"LOW condition code"
    //has switch gone from HIGH to LOW?
    if(thisState == LOW)
      //Do some LOW switch stuff here
      flag12 = true;          //allow timing
      digitalWrite(12, HIGH); //turn on LED
      pin12Millis = millis(); //initialize Timer
  } //END of Switch code
  // similar code for other switches goes here
} //END of checkSwitches()
//                      E N D  O F  C O D E
I need code without delay that would run servos not blinker, i know blinker code alredy.
What you need is in your head.
Show us your sketch, or don’t.
Always show us your current compete sketch.
Use CTRL T to format the sketch.
Please use code tags.
Use the </> icon in the posting menu.
[code] Paste sketch here. [/code]
@Mixailo, read through Robin2's several things at the same time. It has a servo sweep included in it. Without using delay.
i cant show it to you because it absolutely don’t work with delay it is:
#include <Servo.h>
Servo servo0;
int pos0 = 0;
servo1.attach(6);
for(pos0 = 0; pos0 , 180; pos0 += 1)
servo0.write(pos0);
delay(10);
for(pos0 = 180; pos0>=1; pos0-=1)
servo0.write(pos0);
delay(10);
and i should fit in analogWrite with it’s own timing
@vinceherman thanks.
