In the case below, can i know or use the information of wich statement was true?
if(number == 1 || number == 2){
/*other code*/
/*other code*/
Sure. Test each individually before the compound test.
Thank you, but im working on a bigger project and i am worried of my UNO's program storage space. I would like to shorten my code. do i have any other options?
Both conditions could be true and you would never know from your logic.
You can comment or remove the test code after you get satisfactory results of the test(s).
Serial prints are the best debugging tool that you have with the Arduino IDE.
Your math seems to work differently from mine. Where I come from, an integer can only be either "==1" or "==2", not both at once...
Thank you for the answers, but just to be clear.
if(y[x] == z || y[x+1] == z){
y[/*i cant code it to write here x or x+1 depending on which was true*/]--;
It depends. If both are equal to z do you want to decrement both? If so then you will need to do this:
if(y[x] == z)
y[x]--;
if(y[x-1] == z)
y[x-1]--;
There might be a more elegant solution but without knowing your application or the rest of your code I can't say.
Sure, but the logic is faulty is the actual value is important.
if (number == 1 || number == 2) {
Serial.println(number); // print the number
if (number == 1) {
// do something
//number = 2, do something else
Might want to change your logic if the number is a float.
If you describe your project in detail more suggestions can be made
Without more information everything is just guessing.
If you use a lot of text-out to a display all constant textes can be put into flash by using the F-macro.
Though I don't know if you do a lot of text-output I can't really say.
depending on your budget you could buy a different microcontroller with more flash and RAM-memory. An Arduino Mega
if you need just a smaller number of IO-pins or using an I2C-Io-expander is sufficient you could use a $8 cheap Seeeduino XIAO which has 16 times more RAM than an arduino Uno
though I don't know the details I can't say
If you plan to have internet-connectivity using an $10 ESP32 will deliver internet-connectivity combined with plenty of RAM
etc. etc. etc. etc
best regards Stefan
