can i kreate 2 Khz -1/1 V signal some how with an arduino ?
i have an Arduino mega and i want to create 2 Khz -1/1 v sine waves !
can i do it ? and how ?
thank you very much !
kourpetis:
Not directly as AVR chips only use ground and positive Vcc voltages, so not possible to create a negative output voltage directly. And as it has no true analog output functions it cannot even generate a +1vdc output directly. External components and/or modules would be required.
I would look for a bipolar DAC module that uses I2C or SPI communications to work with the arduino. Possibly something like this:
http://www.maximintegrated.com/datasheet/index.mvp/id/4241?utm_expid=50713806-2&utm_referrer=http%3A%2F%2Fwww.google.com%2Furl%3Fsa%3Dt%26rct%3Dj%26q%3Dbipolar%2520dac%26source%3Dweb%26cd%3D3%26sqi%3D2%26ved%3D0CEsQFjAC%26url%3Dhttp%253A%252F%252Fwww.maximintegrated.com%252Fdatasheet%252Findex.mvp%252Fid%252F4241%26ei%3DcZ_MULjxN-nj2QWcu4DwBg%26usg%3DAFQjCNHkhHxZOaZ5F7zprRW7fWm8rJILRQ
Lefty
can i do it ?
Yes.
and how ?
  1. run the mcu at 2v, generate a 0-2v pulse and put a capacitor on the output. On the other side of the capacitor, you have a -1 / +1 Vpp pulse;
  2. if you have to run the mcu at a higher value, you can use a 2v zener / led to limit its swing down to 2v.
Please grow up dhenry you are lowering the standards of the whole forum:-
run the mcu at 2v,
Except you can't.
The guy is asking for a sin wave output -
For a Sin wave?
questions are always easy to answer if you don't read the question.
@henry: Please be serious. You can't run the Arduino Mega at 2V, because it has a 16 MHz crystal or resonator. Plus you could hardly do that without an external power supply, as the USB in, and regulated voltage in, run at 5V.
