I’m working on my project, where i need to use 10 LDR sensors that would mean each one is representing numbers from 1 to 10 (1 number- 1 LDR), that will be shown on display.
My question is, how to read all 10 LDR’s, when on my Arduino UNO are only 6 Analog Inputs.
Thanks for any suggestions, I’m new to Arduino world and I can’t find any answer on internet.
Here's a quote and some test code from the thread I mentioned and then found:
groundFungus:
I have experience using LDRs with Arduino. An LDR must be part of a voltage divider. I usually enable the internal pullup resistor on a pin and wire the LDR from that pin to ground. The pin will read HIGH (1) in the dark and LOW (0) when lighted. If you need to change the sensitivity, use an external resistor from the pin to Vcc and do not enable the internal pullup.
Test code for Mega with LDR to pin 12 and ground.
const byte sensorPin = 12;
boolean sensorState;
pinMode(sensorPin, INPUT_PULLUP); // comment out if using external pullup resistor
static unsigned long timer = 0;
unsigned long interval = 500;
if (millis() - timer >= interval)
sensorState = digitalRead(sensorPin);
Serial.println(sensorState);
You can measure light levels simply and very quickly using a digital port, by using an LDR to charge a capacitor. This can be much faster than using the ADC.
If you start from a discharged capacitor, the time to charge (input port LOW to HIGH transition) is directly related to the LDR resistance. Pololu uses this method for their QTR sensors on line following robots.
jremington:
With an ADC reading taking just over 100 us I don't think it's going to be that much faster, and it's at a cost of serious code overhead.
If it's just for light/dark measurement (as suggested in the OP) I'd pair them with a suitable resistor (value to be determined experimentally; it depends on the actual light levels involved) and use a digital input.
