Can i make my Arduino Nano retain tension?
Hi!
I'm making a project with some friends and we were thinking on using my Arduino Nano to retain tension on the digital inputs that we configure. Is this possible?
I searched on the whole site and didn't found this information.
“retain tension”
More information.
This is a question, not a tutorial. I have suggested to the Moderator to move it to Project Guidance.
...R
Maybe you need INPUT_PULLUP in your pinMode()
I was thinking in the lines of "tie a rope to it and put a sufficient weight on it and you have your tension" but I somehow have the feeling that this is not what is really asked for. I am curious as to what this "tension" should be.
Tension might be voltage if OP is french speaking.
sterretje:
Or old. They used to call HV power lines High Tension Lines.
ChrisTenone:
I'm not native English speaking; so learned something new. Thanks and a karma earned :wink:
sterretje:
I am not english native either and, even with this fact in mind, I do not understand neither ...
Taking for granted that "tension" means voltage (it may happen the OP is spanish native too) what do you mean by "retain tension"?
Regards.
retain tension = record voltage?
PaulRB:
Yes; I guess is that. If so, the OP has to explain what he/she really wants to do ...
Regards
