Can I make this code shorter?
I have been adding to my code information from different examples and from internet.
I don’t understand all what they do… especially about the code of the median filter.
So if any has any comments how it could be shorter (or better), I would really appreciate it.
The program reads from two potentiometers.
After the median filter and if the value has changed more than four then it send the data thru serial .
From serial it reads “1” or “0” to control the stepper motor, and it send the value back thru serial.
#include <Stepper.h>
const int stepsPerRevolution = 200;  // change this to fit the number of steps per revolution
// initialize the stepper library on pins 8 through 11:
Stepper myStepper(stepsPerRevolution, 8,9,10,11);
const int pressureIn1 = A0;  // Analog input pin that the potentiometer is attached to
const int pressureOut1 = 5; // Analog output pin that the LED is attached to
const int pressureIn2 = A1;  // Analog input pin that the potentiometer is attached to
const int pressureOut2 = 6; // Analog output pin that the LED is attached to
unsigned long time = 0;
int dPosition = 0;
int medianSize1 = 5;  //quantity of values to find the median (sample size). Needs to be an odd number
int rangeValue1[] = {
  0, 0, 0, 0, 0};
int medianSize2 = 5;  //quantity of values to find the median (sample size). Needs to be an odd number
int rangeValue2[] = {
  0, 0, 0, 0, 0};
int ledPin = 13;
int value1 = 0;        // value read from the pot
int outpoutValue1 = 0;        // value output to the PWM (analog out)
int value2 = 0;        // value read from the pot
int outputValue2 = 0;        // value output to the PWM (analog out)
int compareData1= 0;
int compareData2 = 0;
  // set the speed at 60 rpm:
  myStepper.setSpeed(60);
  pinMode(ledPin, OUTPUT);
  int midle1 = medianSize1/2;
  int midle2 = medianSize2/2;
  value1 = rangeValue1[midle1];
  value2 = rangeValue2[midle2];
  outpoutValue1 = map(value1, 0, 1023, 0, 255);
  outputValue2 = map(value2, 0, 1023, 0, 255);
  analogWrite(pressureOut1, outpoutValue1);
  analogWrite(pressureOut2, outputValue2);
  delay(10);
    int val = Serial.read() - '0';
    if (val == 1)
      Serial.print("po=");
      dPosition += 1;
      Serial.println(dPosition);
      myStepper.step(stepsPerRevolution);
    else if (val == 0)
      dPosition -= 1;
      myStepper.step(-stepsPerRevolution);
    for(int i = 0; i < medianSize1; i++)
      rangeValue1[i] = analogRead(pressureIn1);
      rangeValue2[i] = analogRead(pressureIn2);
      delay(1);  //wait between analog samples
    isort(rangeValue1, medianSize1);
    isort(rangeValue2, medianSize2);
  if     (value1<compareData1-4 || value1>compareData1+4 || value2<compareData2-4 || value2>compareData2+4)
    time = millis();
    Serial.print("fP=" );
    Serial.print(value1);
    Serial.print("\n");
    Serial.print("sP=" );
    Serial.print(value2);
    Serial.print("\n");
    Serial.print("Ti=" );
    Serial.print(time);
    Serial.print("\n");
  // delay(10);
  compareData1= value1;
  compareData2 = value2;
void isort(int *a, int n)
  for (int i = 1; i < n; ++i)
    int j = a[i];
    int k;
    for (k = i - 1; (k >= 0) && (j < a[k]); k--)
      a[k + 1] = a[k];
    a[k + 1] = j;
void printArray(int *a, int n)
  for (int i = 0; i < n; i++)
    Serial.print(a[i], DEC);
    Serial.print(' ');
Moderator edit: I guess you could make it shorter, but better would be to post it properly using CODE TAGS
Yes, you can. Look at using arrays.
becomes
const int pressureIn[] = { A0, A1 };  // Analog input pins that the potentiometers are attached to
const int pressureOut[] = { 5, 6 }; // Analog output pins that the LEDs are attached to
Similarly, everywhere you read from the pins one at a time, use a for loop to read them together.
Consistency is good…
You have a lot of global variables that should be local to loop.
The outer curly braces are not needed. Get rid of them.
Thank you PaulS for the good tips.
I'll also do not need anymore the LEDs to show me the value of the potentiometer (these will be replaced with sensors). What lines I can remove from the code?
Is there a code, so that the Arduino understand that the stepper motor has reach it's end (not moving anymore)? Or do I need a limit switch or to measure the current to the motor?
Just a run of the mill Stepper.... Limit Switch :)
mill Stepper ??
Is there a code, so that the Arduino understand that the stepper motor has reach it’s end (not moving anymore)?
No, there is no way for the Arduino to know that the stepper is not able to step any more. You need a limit switch or a way to measure current draw to detect a stall (the limit switch is better).
