Can I make two variables share the same memory address?
In another language I work with, I can make two variables of different data-types reference the same patch of memory. I'd do it like this:
StringVar     cstring(10)   -- a string variable
LongVar     long,over(StringVar)   -- a 4-byte numeric variable
The "over" syntax causes the second variable to use the same first 4 bytes as the first. With this I can access the data stored there in two different ways:
So if I do this:
Stringvar='AA' & chr(0) & chr(0)
LongVar will = 16705 (65*256 + 65)
or I can do this:
LongVar=66
and StringVar will = 'B'
Can I do this in Arduino C? Would I use "references" to accomplish this? I've been reading some posts about references but am getting confused.
Thanks!
GB
A union is the conventional way to do it in c. You can, as you surmised, achieve your goal with pointers too.
Technically a union allows one variable to have several runtime types, it doesn't alias two variables - although a union will sort of do what's wanted here if you think of the selector as part of the variable name.
You can simply pass pointers/references around to achieve the effect too, but then the variables have to be explicitly dereferenced with '*' operator (and the references cast to the appropriate type). The union approach is neater I think.
Hey, that Union looks like just the ticket. Any reason it's not in the Arduino language reference? I also notice that when I type it in it doesn't take on the color of a reserved word, yet it seems to compile just fine.
It looks like just what I needed, but I'll post back once I've coded it in and tested it.
Thanks guys
GB
Just wanted to post an update. "Union" worked like a charm -- thanks again to you guys.
If anyone's curious, I'm using it as part of my serial communications coding. I wanted to be able to pass/return any kind of data type (byte, long, string) using common code and data memory. Here's my Union definition:
union byteshare {             // received command data will be placed in CommandDataStr and then access by the appropriate data types
  char CommandDataStr[101];
  byte CommandDataByteA[101];
  byte CommandDataByte;
  int  CommandDataInt;
  long CommandDataLong;
} bs;
bs is right. The key to proper utilization of a union is that everything in the union is the same size.
So:
  char CommandDataStr[4];
  byte CommandDataByteA[4];
  int  CommandDataInt[2];
} bs;
Then, write the code to deal with some number of bs elements. That may involve, for instance, 2 bs's to receive 8 bytes, 8 chars, 2 ints, or 2 longs (or floats). Dynamically or statically allocating the correct number of these elements is important.
Common memory, yes. Common code, no. You need different code to pack a long into this structure than to pack chars or bytes (and to unpack them, of course).
PaulS:
Actually, I read up on Union in a C programming guide somewhere and it stated that you can have different sized variables in a Union (which I have going on here) and it will reserve enough bytes for the largest variable in the Union.
Common code, yes you're right that it won't all be common -- there will be some specific code to handle the different data types. The Union will also relieve me from the task of contructing and deconstructing ints and longs to/from individual bytes.
