Hi I have a question, I would like to build a robot that will be operated with two BLDC motors (If it works) , these need a controller if I now plug the cables from the controller into the motor shield (L293D) does it work like with normal DC motors?
Thanks. Those are brushed motors actually and they come with an ESC which is the controller. You should be able to drive the controllers direct from an Arduino pin with a 5v logic level. These ESCs require a short variable length pulse to set the speed. You do not need a motor control shield.
