Hi, I'm new to using interrupts and am trying to figure out how to print the current value of a variable at a set time using an interrupt. It's a simple oven program, and I want to output a measurement every 5 seconds. I want it to be precise so I figured I'd use an interrupt using Timer1.
The problem is that I get the not so surprising error message of the temperature variable "not declared in this scope" since it's declared in the loop rather than the interrupt.
Is there a way for me to print the current value of the temperature variable in the loop and output it in an interrupt?
You can't. Serial output does not belong in an interrupt handler. It matters not whether the interrupt is an external interrupt or a timer based interrupt.
Which probably does not need interrupts at all. What is generating the interrupts of interest, and why is polling not sufficient?
Every 5 seconds is an eternity as far as the Arduino is concerned, unless you introduce a time warp (aka delay()).
Whether it is surprising or not depends on where you defined the variable. A global variable is always available. A local variable is limited in scope. It isn't clear from your code (hint, hint) where the variable is defined (other than in the wrong scope).
Of course.
Buzzwords like output should be avoided in any technical discussion. There is some specific way of outputting the value that you have in mind. Don't be shy. Just blurt out what that method is.
Thanks for the prompt response. And I’m new to this so any advice RE “buzzwords” and any other conventions are helpful.
So I will provide a little more clarity on what I’m doing/trying to do.
I have 2 Arduino controlled electric ovens, one is 8x2x1.5 feet. Another 18x1.75x1.5. I built them to cure parts for an aircraft manufacturer that I work with. I’m curing a molded part, and the molds are of varying mass/volume. I need to send via serial port a temperature measurement at precise intervals in order to better understand how mass/shape of the mold is affecting rate of heat transfer to the part among several other temperature measurements. One thermocouple is on the part, the other is measuring the ambient temperature inside the oven.
Here’s the very simple code. I’m using a thermocouple library from Adafruit
At this point knowing the precise moment of when the heating element is turned on isn’t really important, the controller is keeping the oven +/-2 degrees F which is fine for this application. I just need the two thermocouples to be reporting at exactly (or as close to exactly) .2 second intervals.
Cool. How are these ovens powered? How fast does the temperature change? I'm only familiar with my home oven and the autoclaves we use at work to cook composite parts. Neither of them have significant changes in measured temperature in a 5 second interval.
How precise? Using millis() to determine if it is time to check/record/send the temperature would get you millisecond resolution. If that's not good enough, try micros() for 250 times better resolution. The micros() function is good for +/- 5 microseconds.
So, millis() will be more than adequate. No interrupts needed.
Ok, this looks perfect. Paul are you a Boeing man? Autoclaves + Seattle...
I made the ovens using 1750 watt electric heating coils that are made for small glass kilns. The 18 footer has 2, so it's running 3500 watts. They're actually much more efficient than I thought they'd be. Temperature increases slightly less than 1 degree F per second initially and only takes about 8 minutes to come up to the 350 degree curing temperature. I either run them off of 2 standard 120v-15Amp circuits or as I did through hurricane Sandy, a little 6000 watt generator.
Our building had no power for 10 days but we kept on cooking parts.
One thing we're doing is that we have a few different models for our mold and we're trying to figure out which performs best. They have different fin configurations that add rigidity of the mold but also increase the surface area of the mold to speed up the rate the mold comes up to temp. We also want to keep them as simple as possible. So we're testing several different molds to see out how they perform.
For the last 33 years, yep.
So, nothing really exotic like 300 degree swings in 20 microseconds. Simply monitoring the temperature, and outputting every 5000 milliseconds sounds reasonable, and easy.
At our refinery we had lots of temperature control loops on very large vessels and columns, some with many thousands of gallons of product boiling off for distillation and because the process time lag is so slow if was among the hardest P&ID control loops to get tuned correctly. Make a tuning change and have to wait a long time to see if it was an improvement or not.
unsigned int milliCount=0;
delay(1);
if (++milliCount==5000) {
// Five seconds have passed
milliCount = 0;
There's that delay() that the whole discussion has been about avoiding. There is no guarantee that the rest of the loop() function will execute in 0 time (in fact, it's guaranteed NOT to), so your method of determining when 5 seconds has passed is guaranteed to fail.
It is stuff like this that gives the Arduino's ability to maintain time a bad reputation.
