I'm currently working on a Arduino Audio Player that plays a wav file from SD Card using PWM Output.
I tried to play wav files with a speaker and also with headphones, connecting the first jumper wire to digital pin 9, and the second one to GND. It worked, and I could hear the music but only as long as I'm fixing the wires as I didn't find a suitable to solder them.
So I would like to know if I can use a buzzer to play the music, because with a buzzer I can just put the two wires inside it without having to solder.
Thanks in advance
Try it but my guess is that it is not so good.
A phobia of soldering irons is not a good thing to have in this hobby.
You should have a series resistor with a regular 8-Ohm speaker or headphones. The maximum allowable current from an Arduino I/O pin is 40mA. From Ohm's Law 5V/0.040 = 200 Ohms minimum. You'll loose volume with the resistor but you won't fry your Arduino.
Or, you can use "powered" computer speakers.
So I would like to know if I can use a buzzer to play the music..
There are two kinds of piezo devices.
A "buzzer" usually has a tone generator built-in. You apply 5V and it makes sound. The frequency is determined by the built-in electronics.
A piezo transducer/speaker reproduces the sound fed-into it. For example, you can generate different tones/frequencies with the tone() function. A piezo speaker is a tweeter (it only reproduces high frequencies... No bass and very little midrange. Musical greeting cards use piezo speakers.
