Can I put the Atmega2560 to works at 8MHz @ 3.3 V?
I have an Atmega2560, and I need integrated with several 3.3V peripherical modules, but I don´t whant to use level converter, is posible make some configuration from the bootloader files, toget the IC works at 3.3V with 8 MHz clock? (I saw a MEGA2560 Pro board tha have this characteristics)
ATmega2560 at 3.3V.
See this thread: ATMEGA2560 at 16MHz 3.3V? - Other Hardware Development - Arduino Forum
Have a look at the ATmega2560 data sheet. You would be overclocking it and/or under powering it, but it may be OK depending on your application. To be completely correct about it, you would actually have to buy ATmega2560V instead of ATmega2560.
