Can I recognize when the NRF24l01 transmitter device is on or off ?
I want to write HIGH to the PIN on the receiver side when the NRF transmitter device is on, and write LOW When it's off,
I wrote this code but sometimes the receiver does not receive any thing until period=30000 and that Makes to be written LOW on the pin and after 30000 receives data.
Is there any other way to know if the transmitter is off?
Transmitter:
#include <SPI.h>
#include <nRF24L01.h>
#include <RF24.h>
// Set the CE & CSN pins
#define CE_PIN   9
#define CSN_PIN 10
#define btn   8
// This is the address used to send/receive
const byte rxAddr[6] = "00001";
// Create a Radio
RF24 radio(CE_PIN, CSN_PIN);
  // Start up the Serial connection
  while (!Serial);
  pinMode(btn, INPUT);
  // Start the Radio!
  radio.begin();
  // Power setting. Due to likelihood of close proximity of the devices, set as RF24_PA_MIN (RF24_PA_MAX is default)
  radio.setPALevel(RF24_PA_MAX); // RF24_PA_MIN, RF24_PA_LOW, RF24_PA_HIGH, RF24_PA_MAX
  // Slower data rate for better range
  radio.setDataRate( RF24_250KBPS ); // RF24_250KBPS, RF24_1MBPS, RF24_2MBPS
  // Number of retries and set tx/rx address
  radio.setRetries(15, 15);
  radio.openWritingPipe(rxAddr);
  // Stop listening, so we can send!
  radio.stopListening();
  // Set up a message and a timestamp to it using millis()
  String str = "on";
  // http://stackoverflow.com/questions/7383606/converting-an-int-or-string-to-a-char-array-on-arduino
  // Length (with one extra character for the null terminator)
  int str_len = str.length() + 1;
  // Prepare the character array (the buffer)
  char char_array[str_len];
  char char_array2[str_len2];
  // Copy it over
  str.toCharArray(char_array, str_len);
  // Ace, let's now send the message
  radio.write(&char_array, sizeof(char_array));
  // Let the ourside world know..
  Serial.print("Sent Message: ");
  Serial.print( char_array );
  Serial.println("");
  // Wait a short while before sending the other one
  delay(2000);
Receiver:
#include <SPI.h>
#include <RF24.h>
#define pin 8
#define led 5
// define the pins
#define CE_PIN   9
#define CSN_PIN 10
// Create a Radio
int cnt=0;
int period =30000;
unsigned long last_rec = 0;
unsigned long now = 0;
unsigned long diff=0;
// The tx/rx address
  // Start the serial
  while(!Serial);
  Serial.println("NRF24L01P Receiver Starting...");
  // Start the radio, again set to min & slow as I'm guessing while testing theire really close to each other
  radio.begin();
  radio.setPALevel(RF24_PA_MAX);   // RF24_PA_MIN ,RF24_PA_LOW, RF24_PA_HIGH, RF24_PA_MAX
  // Set the reading pipe and start listening
  radio.openReadingPipe(0, rxAddr);
  radio.startListening();
  pinMode(pin, OUTPUT);
  pinMode(led, OUTPUT);
  if (radio.available())
    // the buffer to store the received message in
    char text[100] = {0};
    // Now read the message, old examples have done = radio.read(), that doesn't work anymore!!!
    radio.read(&text, sizeof(text));
    // Print the message out to the COM window
    Serial.println("Received Message: ");
    Serial.println(text);
    //Serial.println(sizeof(text));
    if(text[0]=='o'){
    cnt=0;
    digitalWrite(pin, HIGH);
    digitalWrite(led, HIGH);
    //Serial.println("HIGH");
    last_rec=millis();
  else{
       now=millis();
         diff = now - last_rec ;
      if( diff >= period){
      Serial.println("----------------------------------------------not receive-------------------------");
      digitalWrite(pin, LOW);
      digitalWrite(led, LOW);
      now=0;
      last_rec=0;
The concept of the nRF24 transmitter being on or off is a false one. It only transmits when you call radio.write() and then only for the very short time needed to send the message. At all other times it is idle.
The only way to know if the transmitter works is when the receiver gets the message - and if it fails to get the message the fault could equally well be in the receiver.
If you want your receiver to be able to identify when there is a communication problem then you need to arrange for the TX to send a message at regular intervals (perhaps 5 times per second) and then if no message arrives for (say) 1 second the receiver can be fairly sure there is a problem. Some failed messages will be normal due to external interference.
If there are a lot of failed messages it would be a good idea to try working on a different channel (different frequency).
...R
Simple nRF24L01+ Tutorial
Robin2:
Can you show me with the code please?
Something like this
if (radio.available() {
   // code to read the message
   lastTimeMessageReceived = millis();
if (millis() - lastTimeMessageReceived >= acceptablePeriod) {
   // there is a problem so do do something
...R
