can I run a .68A motor ?
I plan to build the motor shield http://www.ladyada.net/make/mshield/
but the specs say it can only handle .6 A for a stepper
I only plan to run 1 motor total.. I would like to run this one: http://www.robotshop.us/rbsoy14-soyo-un ... motor.html
but it draws .68A
think it would be OK ?
If it's relatively unloaded, put an ammeter on it to see how much current is actually being drawn during use.
You can get a DIP heatsink to help the LM293D chips run a little cooler.
Or try the time honored thing and stack the chips to double your current capacity. It's mentioned on the LadyAda webpage http://www.ladyada.net/make/mshield/use.html as follows:
Need more power? Buy another set of L293D drivers and solder them right on top of the ones on the board (piggyback). Voila, double the current capability!
I would like to run this one: but it draws .68A
If the spec says the absolute maximum is 0.6A then that's it. It's like trying to put a 6' wide car in a garage that is only 5' 11.5" wide, it's a no go. In fact in engineering terms if the spec says 0.6A they I would be reluctant to put any more than 0.5A through it.
