Can i run the ARDUINO NANO with anImpulsewidth of 40ms?
Hello,
I have a testrack with 2 sensors attached to a cylinder. The sensors count the amount of time an object takes from the first to the second sensor by dropping through the cylinder.
I tried it with an stop watch. With the debouncing and a signal of 40ms the stop watch was not able to count the time correctly.
My relay will give me a 40ms pulse if something passes a sensor. Can i trigger that event with an ADRUINO NANO? If not is there anohter ADRUINO device which could help me with it?
I have searched through a lot of forums and stuff but i couldn´t find that information.
Thanks in advance!
Dia
I don’t really understand your description. If it is any help 40 millisecs is a long time for an Arduino so it should be quite capable of doing what you want.
Can you draw a diagram that illustrates the signal that you want to detect and post a photo of the drawing.
What sensors are you using? Post a link to their datasheet,
…R
hello,
the sensors we use are the MK5201 magnetic sensors. Link to the sensor Family:
These are my signal diagram pictures.
is the arduino able to trigger on this event to start/stop the timer?
Dia
Yes, with ease.
Thanks for the answer.
Dia
Be sure not to connect that 24V signal directly to your Arduino!
