Can I run the arduino without usb?
Subject~~ help ... :frowning:
Yes. You need to supply power, either through the barrel jack or (regulated, 5V) the Vin pin.
PaulS:
The Vin pin goes to the onboard 5V regulator. You have to feed it at least 7V to get regulated 5V out of the regulator.
Regulated 5V goes to the "+5V" pin.
The barrel connecter is preferred because it has a diode to protect against reverse polarity.
