Can i SerialPort.write(String)?
Hi
I have been trying to send some Strings using rx tx communication.
If I use SerialPort.write i cant send strings unless i write SerialPort.write("something").
I cant use already nominated strings to send.
This is the code of the master(sender):
#include <HardwareSerial.h>
HardwareSerial SerialPort(2);  // use UART2
int numero;
int numero1;
String number;
int number1;
  SerialPort.begin(115200, SERIAL_8N1, 17, 16);
  delay(2500);
  number = "143";
  SerialPort.write(number);
  delay(2500);
  numero = 110;
  numero1 = 165;
  SerialPort.write(numero, numero1);*/
And this is the code of the Slave(receiver):
int num;
String number;
String numb1;
String numb2;
  if (SerialPort.available()) {
    number = SerialPort.readString();
    Serial.println(number);
    numb1 = number.substring(0, 3);
    Serial.println(numb1);
    numb2 = number.substring(4, 7);
    Serial.println(numb2);
'SerialPort.print()'
can i grab that string then in the receiver and use it?
This will explain the proper way to communicate between two boards using Serial
Serial Input Basics - updated
Did you try?
after many tried i was able to convert my ints to strings and send them
