I have now 5 of those that got their USB damaged in a way that it will power from USB, but the usb-serial chip is dead, so I can't flash them the normal way anymore. This happened when I plugged them into some board that does something I haven't figured out yet, but indeed seems to destroy the USB chip somehow.
They otherwise work fine, I can get output on the serial pins via an ftdi serial adapter, and I can also send input, my code receives it and it works.
So I should still be able to flash them via those serial pins, no?
I do see the normal messages from the ESP32 bootloader on serial but when running the arduino flasher, I get
Connecting........_____....._____....._____....._____....._____....._____....._____....._____....._____....._____
A fatal error occurred: Failed to connect to ESP32: Timed out waiting for packet header
I tried to push the reset button during this time, and it didn't help.
I also tried to short GPIO0 to GND or connect it via a 10k resistor before or after pushing the reset button and during this time arduino is trying to connect, but again, no luck.
If the burned USB chip is not tie down or tie up the serial pins of the ESP32, you may be able to program them using a USB/TTL module.
You may remove your bad interface too.
I use it here on my ESP32 standalones.
I used one of those (mentioned ftdi usb serial adapter).
The one thing I may not have done right is that I was powering the chip via USB. I could try to power it directly without powering the damaged USB chip at all.
i'm not sure why it wasn't working when I first tried, but it is working now after pulling GPIO to GND while pushing RST to enable flash mode
rst:0x1 (POWERON_RESET),boot:0x3 (DOWNLOAD_BOOT(UART0/UART1/SDIO_REI_REO_V2))
waiting for download
Now that i've figured out how to flash around a broken USB chip I need to figure out why I'm burning those chips.
I'm not connected the USB header to anything other than my laptop, and I do power the chip from an external 5V source directly on its USB pin, and it should be about 5V. Is there a way to fry the USB chip without frying the ESP32 voltage regulator?
Sure, not surprisingly the USB chip is connected directly to the 5V rail and not protected by the voltage regulator.
I suppose that means my circuit could send more than 5V, but I'm not sure it does, or something like 5.1 or at most 5.2V, I'd have to go measure it.
