Can I store a string literal that would be called in a function in PROGMEM
So basically, I'm running out of SRAM and am starting to get unknown behaviour and was wondering I had a function like so:
void function(String str){
   //do some stuff
and the "str" variable is constant could I store it in eeprom to save memory or declare it as a constant or would this have no effect on the amount of SRAM used. I am asking because I call the same string literal in several functions.
Finally how would I go about storing it in eeprom a lot of the examples are a bit confusing
Many thanks for any help.
Why use Strings (uppercase S) and not C-strings (lowercase s) ?
There is a difference
You can do this :
const char PROGMEM test[] = {"This is a test"};
char buffer[20];
  while (!Serial);
  int len = strlen_P(test);
  for (int k = 0; k < len; k++)
    char myChar =  pgm_read_byte_near(test + k);
    Serial.print(myChar);
To save SRAM, for Serial.prints be sure to use the "F" macro (also stores the text in program memory), e.g.
Serial.println(F("Starting up!"));
Thanks, that what I'm using now and memory seems good so far! :slight_smile:
