can i stream audio between my cell phone and a PC using HC-06 Module
I want to transfer the call audio from my cell phone (non-smartphone) to a PC via Bluetooth But the cell phone only streams audio to a audio device
therefore I need to turn the PC into a audio Bluetooth slave
So I searched for a software that could do the job but I was told an "quora.com" that such a thing doesn't exist you'll have to build the software yourself
Here's my question Can I use a "USB CP2102 Converter + HC-06 Module" I found In order to stream audio from the cell phone to a PC
(I don't want to use a Bluetooth transmitter because it can't transfer and receive together)
Thanks guys.
Here's the Module link Click here
No.
But the HC-06 Module is a Bluetooth module.
thanks for the answer
Maybe you have some other solution or a different device (module) that can do the job
about the "Bluetooth transmitter" I meant like this one (Maybe it's called a "Bluetooth audio transmitter" It has the option of or RX or TX)
If someone could help me out I'll be very thankful
Thanks again guys
