Can i use a switch case for two variables
I’m currently working on a project (Object following robot) and was wondering if its possible to use switch case with two variables (Ultrasonic Sensors) I am currently using if else but its not going well. Maybe someone out there could throw me some pointers or tell me what I am doing wrong. I’m new to the forum and hope i have put this in the right place. Thanks in advance.
A_Setup.ino (788 Bytes)
B_Loop.ino (2.17 KB)
Capstone_V2.0.ino (1.53 KB)
No. A switch statement lets you choose one case based on one value.
You posted some code, but did not tell us what it does, or how that differs from what you want.
PaulS: No. A switch statement lets you choose one case based on one value.
Well, you could use a fall through and have several cases based on certain values...
switch(value)
  case a:
    functionA();
  case b:
    functionB();
  case c:
    functionC();
  default:
You can combine two variables into a single new variable, and use that in the switch. For example, if you have two variables, one that can have values 0, 1 or 2, and the other can have the values 3,4 or 5, you can combine them:
int thing1;  // Can have values 0, 1 or 2
int thing2;  // Can have values 3, 4 or 5
int switchvar = (thing1 * 10) | thing2;
switch (switchvar)
    case 3:    // thing1==0, thing2==3
    case 13:    // thing1==1, thing2==3
    case 23:    // thing1==2, thing2==3
    case 4:    // thing1==0, thing2==4
    case 14:    // thing1==1, thing2==4
    case 24:    // thing1==2, thing2==4
    case 5:    // thing1==0, thing2==5
    case 15:    // thing1==1, thing2==5
    case 25:    // thing1==2, thing2==5
Regards, Ray L.
