Can I use a transistor instead of a push button?
Hi guys,
I need some help with my project please, basically Im trying to make a circuit which controls a motor in forward and reverse mode but wirelessly using a USB Host Shield + Bluetooth dongle and controlling it with a ps3 controller but the problem is I have seen a circuit on the web its this one: http://api.ning.com/files/jFhR10F2nKDm5cJ0p2jcpgHpKd4hNPz01QgMS8OF6QUh82aIgvr-dp1uzQSopb*PQgSlhFEgj5ALhek3X56Zq6xDZuw-9vwD/l293dmontagem.jpeg
basically in that picture there is a push button and what I wanted to do was have a wireless project but because of the push button it is not allowing me to advance further so I was wondering could I use some sort of transistor to act as that switch but that the switiching would be controlled by the arduino itself? or is there any other way where I could get the arduino to do the switching
here is the Arduino code that was on the website where I found that picture:
int switchPin = 2; // switch input
int motor1Pin1 = 3; // pin 2 on L293D
int motor1Pin2 = 4; // pin 7 on L293D
int enablePin = 9; // pin 1 on L293D
void setup() {    // set the switch as an input:
pinMode(switchPin, INPUT);    // set all the other pins you're using as outputs:
pinMode(motor1Pin1, OUTPUT);    pinMode(motor1Pin2, OUTPUT);    pinMode(enablePin, OUTPUT);    // set enablePin high so that motor can turn on:
digitalWrite(enablePin, HIGH);
void loop() {    // if the switch is high, motor will turn on one direction:
if (digitalRead(switchPin) == HIGH)
digitalWrite(motor1Pin1, LOW); // set pin 2 on L293D low
digitalWrite(motor1Pin2, HIGH); // set pin 7 on L293D high
}    // if the switch is low, motor will turn in the opposite direction:
digitalWrite(motor1Pin1, HIGH); // set pin 2 on L293D high
digitalWrite(motor1Pin2, LOW); // set pin 7 on L293D low
I think you’re overthinking this… The “if” that checks if the switch is pressed or not, does the reversing of the motor through the L293 which is already a bunch of transistors.
If the Arduino is accessible to you via USB and BT, about which I know <0 I might add, you already have access to the L293 tht way.
So you could do something like this… instead of:
… say something like:
if (blueToothSignal == ClockWise)
That’s totally conceptual of course, I have no idea what a BT signal looks like, but I’m sure you can pick up from here.
I tried that in the below code it didnt work too well but yea what i actually wanted to do was if I pressed the UP button the motor would run forward and if I pressed DOWN it would run in reverse but I cant seem to figure it out hence why I asked about the switching
 #include <PS3BT.h>
#include <Servo.h>
Servo manzoorsServo;
USB Usb;
BTD Btd(&Usb);
PS3BT PS3(&Btd);
int servoPin = 6;
    manzoorsServo.attach(servoPin);
    if (Usb.Init() == -1) {
    Serial.print(F("\r\nOSC did not start"));
    while(1);
    Serial.print(F("\r\nPS3 Bluetooth Library Started"));
  Usb.Task();
  if(PS3.PS3Connected || PS3.PS3NavigationConnected)
       manzoorsServo.write(map(PS3.getAnalogHat(RightHatX), 0, 255, 0, 120));
       manzoorsServo.write(115);
if (PS3.getButtonClick(UP))
digitalWrite(motor1Pin1, HIGH); // set pin 2 on L293D low
digitalWrite(motor1Pin2, LOW); // set pin 7 on L293D high
if (PS3.getButtonClick(DOWN))
digitalWrite(motor1Pin1, LOW); // set pin 2 on L293D high
digitalWrite(motor1Pin2, HIGH); // set pin 7 on L293D low
       if(PS3.getButtonClick(PS)) {
       PS3.disconnect();
As you can see from this I have removed the switchpin because like I said I want the motor to go forward when I press UP and reverse when I press DOWN
Greats minds thinking alike then....
If I were you I'd use Serial.println() to print messages to the console so you can see if the logic is actually taking you where you expect / hope. Print a message like "I should be going forward now" or whatever, in the appropriate legs of the if statements.
