I know i could use the barrel jack and the usb power at the same time with the UNO R3, and the barrel jack will be the main power if it exceeds 7.2V, BUT i don't know if i can do the same with the UNO R4 WiFi (and Minima)? And if so at what voltage does it choose the barrel jack one?
Also i wonder if this way i could or couldn't use the OFF pin? If i use the usb-c for power, this functionality is disabled by hardware.
Edit: i tried it, and it works, only that the OFF pin is still unusable. Also i don't know the voltage that it switches and i don't know why but when i connect the barrel jack (12V 1A adapter), every LED (7seg and two simple ones are connected) is a tiny-tiny bit brighter.
