Can I use both external interrupt and Timer?
When I use Arduino mega 2560, digital pin 3 is PE5/OC3C/INT5
I am using this pin as external falling interrupt.
And I want to use Timer3 now.
I know that OC3C is output pin when timer interrupt is generated, (if I set COMnA or B or C in TCCRn register )
but I want to use this Timer3 just as timer interrupt operation, not port operation like OC3C.
In this case, Can I use both Timer3 and INT5 at the same time?
Does Timer3 function affect INT5?
At 99% you can do it.
ok i try
Smajdalf:
Thank you my friends ,
But Smajdalf, why did you say that I can do it 99%?
Are there some exceptions?
wogkr3654:
It is possible on every AVR I know about. I don't know Mega2560 and I am pretty sure it will work. But I didn't try it.
