Can i use the RX and TX pins?
Can i use the RX and TX pins on the arduino?
My project needs exactly 13 pins and i cant find a mega arduino.
So can i use them?
You can use A0-A5 as digital inputs/outputs too.
Using D0 and D1 could cause problems.
so what do i have to do to use A0 and A5 ??
do i type the code ( (pinMode,OUTPUT))???
in setup()...
pinMode(A0, OUTPUT);
in loop()...
digitalWrite(A0, HIGH);
or...
declare the pin first
const byte daPin = A0;
then, in setup()...
pinMode(daPin, OUTPUT);
and in loop()...
digitalWrite(daPin, HIGH);
Leo..
Also, A0 is D14, A1 is D15 etc.
ex. set 2-19 to outputs
for(byte x = 2; x < 20; x++)
pinMode( x, OUTPUT );
True, but 14-19 is not working on every Arduino.
Leo..
Wawa:
Leo..
how do i check if it works on mine??
Did you try it?
What Arduino board do you have?
A0-A5 or 14-19 both work on an Uno/Nano.
Leo..
ok thanks guys i have an arduino uno
