Can i use this code for run 2 rfid with arduino mega ? please help!
#include <SPI.h>
#include <MFRC522.h>
#define SS_PIN 10
#define SS_2_PIN 11
#define RST_PIN 9
MFRC522 mfrc522(SS_PIN, RST_PIN);
MFRC522 mfrc522_2(SS_2_PIN, RST_PIN);// Create MFRC522 instance.
int count = 0;
int count2 = 0;
Serial.begin(9600); // Initiate a serial communication
SPI.begin(); // Initiate SPI bus
mfrc522.PCD_Init(); // Initiate MFRC522
mfrc522_2.PCD_Init(); // Initiate MFRC522
Serial.println("Put your card to the reader for scanning …");
// Look for new cards
if ( ! mfrc522.PICC_IsNewCardPresent())
return;
// Select one of the cards
if ( ! mfrc522.PICC_ReadCardSerial())
return;
//Show UID on serial monitor
Serial.print("UID tag :");
String content= "";
byte letter;
for (byte i = 0; i < mfrc522.uid.size; i++)
Serial.print(mfrc522.uid.uidByte[i] < 0x10 ? " 0″": " ");
Serial.print(mfrc522.uid.uidByte[i], HEX);
content.concat(String(mfrc522.uid.uidByte[i] < 0x10 ? " 0" : " "));
content.concat(String(mfrc522.uid.uidByte[i], HEX));
Serial.print("Message : ");
content.toUpperCase();
String value1 = content.substring(1);
if ( value1 == ("AB CD EF GH") )// enter your own card number after copying it from serial monitor
count = count+1;
else{}
switch (count)
case 1:
if ( digitalRead(4)==0,digitalRead(6)==0,digitalRead(7)==0)
for(int i = 0;i<255;i++)
digitalWrite(5,i);
digitalWrite(8,HIGH);
digitalWrite(8,LOW);
else{}
case 2:
count=count-2;
if ( ! mfrc522_2.PICC_IsNewCardPresent())
return;
if ( ! mfrc522_2.PICC_ReadCardSerial())
return;
Serial.print("2_UID tag :");
String content2 = "";
byte letter2;
for (byte i = 0; i < mfrc522_2.uid.size; i++)
Serial.print(mfrc522_2.uid.uidByte[i] < 0x10 ? " 0″": " ");
Serial.print(mfrc522_2.uid.uidByte[i], HEX);
content2.concat(String(mfrc522_2.uid.uidByte[i] < 0x10 ? " 0" : " "));
content2.concat(String(mfrc522_2.uid.uidByte[i], HEX));
content2.toUpperCase();
String value2 = content2.substring(1);
if ( value2 == ("AB CD EF GH") )// enter your own card number after copying it from serial monitor
count2 = count2+1;
else{}
switch (count)
case 1:
if ( digitalRead(14)==0,digitalRead(15)==0,digitalRead(16)==0)
digitalWrite(17,i);
else{}
case 2:
digitalWrite(9,HIGH);
digitalWrite(9,LOW);
count2=count2-2;
Work through this…
I don’t think it’s going to do what you’re expecting.
PLUS, forum etiquette asks that you read the guides, and post code appropriately in code tags.
I don't know about code tags so..
This code is example , i will do other operation .
Then you obviously haven’t read the forum guidelines.
There are a lot of people here that want to help, but the harder you make it, the less help you’ll get.
Sorry, harsh truth.
You can spend about 3 or 4 weeks playing the guessing game, or you give up unless you get lucky. Code tages and an annotated schematic will probably cut that to 2 or 3 days for a solid answer, many times less than a day. If you can read it should take less than 1/2 hour to read the guidelines. That will save us hours like many of us , me included will not take the time to play the game. There are a lot of excuses for not doing a schematic but great tools are available free but it will take a bit of learning on your end to use them.
Post the schematic as you have it wired, not a fritzing diagram and include links to technical information on the hardware items including the board etc. For all I know you could be trying to run this on a PDP11.
