Can I use Two battery of 9V batteries for 2WD arduino car? It show not enough power
Hi, I need confirmation. Right now, I using two 9volt batteries and combine it together to 18volt. I know that Bridge only need 12volt. But when I running it, it looks like it not enough power. Need help asap thank you. Can someone explain why AA batteries more suitable than 9V batteries?
![image|375x500](upload://nYQ
yKRienqp5yEi8q4HhSAVThIk.jpeg)
x
Those types of 9V batteries have very little current supply capabilities. By using those batteries your project is running normally.
It's about current not voltage.
This is not and installation or troubleshooting issue
Meaning - "As well as it could with that."
sorry about that
How about I change it with Lipo lithium battery 11.1V 3s 25C 1500mAh . Is this okay for my project. Any suggestion please.
@nazrulalzam, your topic has been moved to a more suitable location on the forum. Installation and Troubleshooting is not for problems with (nor for advice on) your project :wink: See About the Installation & Troubleshooting category.
https://forum.arduino.cc/t/should-i-buy-this-batteries-for-my-arduino-car-project-with-3-extra-servo-motor/1000378
Is the new topic.
Hi, I would like to have some suggestion from you guys. I make a mistake by using two 9volt batteries and combine it together to 16volt. It was a lot of voltage but low current. So I would like to ask does - lipo lithium battery 11.1V 3s 25C 1500 mAh enough for this project. Like I said I will add on 3 more MG996R servo motor.
Thank you for reply and helping me.
Your two topics on the same or similar subject have been merged.
Please do not duplicate your questions as doing so wastes the time and effort of the volunteers trying to help you as they are then answering the same thing in different places.
Repeated duplicate posting could result in a temporary or permanent ban from the forum.
Could you take a few moments to Learn How To Use The Forum
  • Your OS and version can be valuable information, please include it along with extra security you are using.
  • Always list the version of the IDE you are using and the board version if applicable.
  • Use quote or add error messages as an attachment NOT a picture.
  • How to insert an image into your post. ( Thanks @sterretje )
  • Add your sketch where applicable but please use CODE TAGS ( </> )
  • Add a SCHEMATIC were needed even if it is hand drawn
  • Add working links to any specific hardware as needed (NOT links to similar items)
  • Remember that the people trying to help cannot see your problem so give as much information as you can
COMMON ISSUES
  • Ensure you have FULLY inserted the USB cables.
  • Check you have a COMMON GROUND where required. ( Thanks @Perry)
  • Where possible use USB 2.0 ports or a USB 2.0 POWERED HUB to rule out USB 3.0 issues.
  • Try other computers where possible.
  • Try other USB leads where possible.
  • You may not have the correct driver installed. CH340/341 or CP2102 or FT232 VCP Drivers - FTDI
  • There may be a problem with the board check or remove your wiring first.
  • Remove any items connected to pins 0 and 1.
COMPUTER RELATED
  • Close any other serial programs before opening the IDE.
  • Ensure you turn off any additional security / antivirus just to test.
  • There may be a problem with the PC try RESTARTING it.
  • You may be selecting the wrong COM port.
  • Avoid cloud/network based installations where possible OR ensure your Network/Cloud software is RUNNING.
  • Clear your browsers CACHE.
  • Close the IDE before using any other serial programs.
  • Preferably install IDE’s as ADMINISTRATOR or your OS equivalent
ARDUINO SPECIFIC BOARDS
  • CH340/341 based clones do not report useful information to the “get board info” button.
  • NANO (Old Types) some require you to use the OLD BOOTLOADER option.
  • NANO (ALL Types) See the specific sections lower in the forum.
  • NANO (NEW Types) Install your board CORE’s.
  • Unless using EXTERNAL PROGRAMMERS please leave the IDE selection at default “AVRISP mkII”.
  • Boards using a MICRO usb connector need a cable that is both DATA and CHARGE. Many are CHARGE ONLY.
CREATE editor install locations.
  • On macOs ~/Applications/ArduinoCreateAgent-1.1/ArduinoCreateAgent.app/Contents/MacOS/config.ini
  • On Linux ~/ArduinoCreateAgent-1.1/config.ini
  • On Windows C:\Users[your user]\AppData\Roaming\ArduinoCreateAgent-1.1
Performing the above actions may help resolve your problem without further help.
Language problem ?
Try a language closer to your native language:
Thanks to all those who helped and added to this list.
Thank you.
Very likely.
To be sure create a power budget; how much is your load(s), i.e what current will the motors draw, what other loads.
What current can the batteries supply, if that is more than you load total, plus a margin then you are OK.
