Can i use tx rx pins ? Pro micro
Hi, so basically tosum up my problemis i simulated my code through tinkercad with an UNO card . I only used 18 buttons plugged to 18 input pins based in the infirmation i found online that the pro micro has 18 input pins .
It cae todzy trough the mail and ti only count 16 . Afer some research i found that they count the tx and rx pins in the 18 they use to market them ... .
I m here to ask fi i can use those pins or is there something else i can do to fit the extra 2 buttons i have ? Can i use those tx rx pins ?
My code is going to make the game act ad a gamepad for windows using the gamepad library . So i need c9nnection between my oc and the board.
People say if u dont need serial u can use those pins but ither people say serial is there to communicate with ur pc which i think i need to be able to se'd the infos of the keystrokes of the gamepad to the pc ... But. I m not sure as i never did something like this before and i m getting a bit confused tbh i dont even know if i need serial or not or what exactly is serial .
so can someone elaborate on this please before i solder them and fry my card or do something even worse ?
Thanks in advance
Use of real words to explain would help, not your made-up abbreviations.
You can, but you can also set up your buttons in a 5x4 matrix and only use 9 pins for 18 buttons.
Google "keypad matrix Arduino"
I believe that works.
EDIT: it does work, including TX and RX pins.
Try what @er_name_not_found said and use the keypad.h library.
The ProMicro uses a 32U4 where the UART (TX and RX pins) is NOT used for communication with the PC. So you can use them as IO without interfering with uploads and serial monitor.
Lol sorry . I m bad at using a smartphone keyboard i ve seen it again now and it s full of mistakes . Others got it tho so it probably wasnt that bad :smiley: lol .
Thank u very much for the info . Bless u all :slight_smile:
