Can integer values be assigned to I/O prts?
I just recently retired & I'm anxious to get an Arduino & start learning how to use it.
Can I assign random integer values to the I/O ports?
What I want to do is use the Random function to create a random brightness value between 0 & 255 & assign it to an LED that's connected to an I/O port on the Arduino. Can I use the Random function to randomly choose I/O ports?
This might be of interest:
http://arduino.cc/en/Tutorial/Fade
You want to randomly pick the PWM capable IO port (a byte value) that will have a random 0-255 (also a byte value) written to it? I suppose so.
Something like:
  analogWrite (pin_table [random (4)], random (256)) ;
where pin_table maps 0..3 to 4 PWM pin numbers?
You consfuse "pin" and "port" - a pin is a single logic signal, a port is a group of pins controlled by the same internal registers on the microcontroller - the Arduino functions hide ports from you, you don't need to know about them if you don't want to.
yes, with byte pin_table[] = {3,5,6,9,}; // 10, 11 also available on an Uno for example.
