Can it be connected with UTFT and URTouch
Here is the display
I managed to load some of the demo programs once it worked under adafruit library and also mcufriend library. the problem are different instructions I have wrote for different display using UTFT and URTouch.
It has driver ILI9486, it says wired for portrait. it is 320 x 480
I tried to change the pins but nothing works
Your JPEG shows a Blue Mcufriend style Shield.
It will not work with UTFT or URTouch libraries.
Install the MCUFRIEND_kbv library via the Library Manager.
You can not change the pins. The shield plugs into an Arduino in one way.
David.
