hello forum. my question is prety much, what the tittle says... what i eaxctly want to do, is something like that :
have an arduino(1) read some sensors, and calculate some numbers. then convert them to a serial string, and outpout it, via the digital pins, 0 and 1..
on the other side, i want to have
another arduino(2), to read that serial directly from the arduino(1)'s output pins.
2)a Bluetooth module, that connects to the arduino(1)'s output pins and the connects to a pc.
3)a TTL to usb converter, wich then connects to enother pc...
is this ale to be done at all? or am i just flying in clouds?
Physically you can do this. However, you will get all the gumf that bolo tooth needs sent to the other devices. While many devices can pick up a serial output from the arduino, Only one device can be wired to talk back to the arduino.
And if you have several devices connected to the same output pin it might be a good idea to have a buffer chip in between - such as a 74HC4050 according to my 1996 book.
One could also daisychain the Arduinos, ie the TX of Arduino#1 goes to RX of Arduino#2, the TX of #2 goes to RX of #3 ... Of course the code needs to replicate the character.
And if you close the loop with the last Arduino connected to the first, then you have reinvented the Token Ring ((Sounds like a nice project, for those that like to write protocol software.- but I digress))
