Can Mega emulate usb keyboard
Ive read some post that suggest it can but I have to reprogram the mega. I want to use 3 or four shift registers connected to 24 pushbuttons when I push a button I want the mega to print out 2 letters in Notepad. Two differnet combination of two letters for each of the 24 buttons
Can this be done
Rick
I haven't tried it, but it's supposed to be possible: GitHub - NicoHood/HID: Bring enhanced HID functions to your Arduino!
It may be possible, but probably much easier if you have a board like the Leonardo that has USB host capabilities.
I think the UNO can as well..
I believe any 8u2/16u2..etc based chips need to be reflashed for this behavior? (didnt check out link, so maybe thats different)
xl97:
But when you do that, be forewarned that you can no longer upload your code over the USB and will have to flash your code in a different way like ISP.
xl97:
Yes, that's correct. It's using the USB to serial chip for the emulation. You need to flash it with GitHub - NicoHood/HoodLoader2: 16u2 Bootloader to reprogram 16u2 + 328/2560 with Arduino IDE. This means if you have a clone Uno with a CH340 chip or a board with an FTDI FT232RL it won't work.
Delta_G:
Hoodloader2 claims to still allow USB uploads(though it's a bit more complex than normal: Uploading programs · NicoHood/HoodLoader2 Wiki · GitHub
