Hi Klaus,
Sorry typo on SPI, I use 5M instead of default 10M.
Yes library is the one from Sandeep Mistry.
In the ISR I set pin 37 first thing, and clear it last thing. All the printing is commented out. The receiving ISR only takes 100us. From the scope trace, you can see that the ISR is not even entered until after the second CAN message is received. This is my issue. The MPC2515 has 2 receive buffers but I am not sure how the library gets data from the buffers - does it automatically get data from both or only one? When received - does the library clear the buffers?
I am an old plain C guy, I am very weak at C++ so I have not really dived into the library code itself.
Here is the whole sketch - a lot is the LCD and UI.
type or paste code here
* CAN Program - reads CAN data
* Assumes no data element more that 16 bits
#include <CAN.h>
#include <EEPROM.h>
#include <LCDWIKI_GUI.h> //Core graphics library
#include <LCDWIKI_KBV.h> //Hardware-specific library
#include <TouchScreen.h> //touch library
LCDWIKI_KBV mylcd(ILI9486,A3,A2,A1,A0,A4); //Instantiate the LCD with parameters model,cs,cd,wr,rd,reset
//Define some items for touchscreen
#define YP A3 // must be an analog pin, use "An" notation!
#define XM A2 // must be an analog pin, use "An" notation!
#define YM 9 // can be a digital pin
#define XP 8 // can be a digital pin
//param calibration from kbv
#define TS_MINX 906
#define TS_MAXX 116
#define TS_MINY 92
#define TS_MAXY 952
#define MINPRESSURE 10
#define MAXPRESSURE 1000
#define TOUCHTHRESH 100
#define PRESSDELAY 20 //ms delay for each press
// For better pressure precision, we need to know the resistance
// between X+ and X- Use any multimeter to read it
// For the one we're using, its 300 ohms across the X plate
TouchScreen ts = TouchScreen(XP, YP, XM, YM, 300); //Instantiate the touchscreen
//define some colour values
#define BLACK 0x0000
#define BLUE 0x001F
#define RED 0xF800
#define GREEN 0x07E0
#define CYAN 0x07FF
#define MAGENTA 0xF81F
#define YELLOW 0xFFE0
#define WHITE 0xFFFF
#define GREY (BLUE/16 + RED/16 + GREEN/16)
#define TFT_NAVY 0x000F /* 0, 0, 128 */
#define TFT_DARKGREEN 0x03E0 /* 0, 128, 0 */
#define TFT_DARKCYAN 0x03EF /* 0, 128, 128 */
#define TFT_MAROON 0x7800 /* 128, 0, 0 */
#define TFT_PURPLE 0x780F /* 128, 0, 128 */
#define TFT_OLIVE 0x7BE0 /* 128, 128, 0 */
#define TFT_LIGHTGREY 0xC618 /* 192, 192, 192 */
#define TFT_DARKGREY 0x7BEF /* 128, 128, 128 */
#define TFT_BLUE 0x001F /* 0, 0, 255 */
#define TFT_GREEN 0x07E0 /* 0, 255, 0 */
#define TFT_CYAN 0x07FF /* 0, 255, 255 */
#define TFT_RED 0xF800 /* 255, 0, 0 */
#define TFT_MAGENTA 0xF81F /* 255, 0, 255 */
#define TFT_YELLOW 0xFFE0 /* 255, 255, 0 */
#define TFT_WHITE 0xFFFF /* 255, 255, 255 */
#define TFT_ORANGE 0xFDA0 /* 255, 180, 0 */
#define TFT_GREENYELLOW 0xB7E0 /* 180, 255, 0 */
#define TFT_PINK 0xFC9F /* 255, 128, 255 */
/*#define TFT_ORANGE 0xFC00 /* 255, 128, 0 */
#define BACKCOLOR BLACK
#define UPARROW 24 //ASCII code for up arrow
#define DOWNARROW 25 //ASCII code for down arrow
#define ARROWWID 39 //Arrow button width in pixels
#define ARROWHEI 40 //Arrow button height in pixels
#define ARROWTEXTSIZE 5 //Arrow text size. 5*7 = 35 pixels high, fits in 40 high box
#define ARROWRAD 3 //Arrow button radius - make sharper corners than regular button
#define NORMAL 0 //Normal or inverted for buttons
#define INVERT 1
#define ARROWTEXTCOLOR BLACK //Arrow text color
#define ARROWBUTTONCOLOR WHITE//Arrow button color
#define BUTTONWID 140 //Menu button width in pixels
#define BUTTONHEI 45 //Menu button height in pixels
#define BUTTONTEXTSIZE 4 //Menu button text size
#define BUTTONRAD 5 //Menu button corner radius - soft
#define SEQTEXTSIZE 8 //Sequence numbers size 6
#define TITLETEXTSIZE 6 //Title text size 6
#define TEXTSIZE 4 //Size of regular text
#define DATATEXTSIZE 2 //Size of data text
#define NUMDATALINES (270/(DATATEXTSIZE*9)-1) //Number of lines
#define NUMDATACHARS 480/(DATATEXTSIZE*6) //Number of characters per line
#define DATAy 50 //x coord of where data starts
#define DATAx (wid-BUTTONWID) //Y of where data ends
//Generally have 4 lines. 50 pixels high. 40 pixels between lines
#define LINE1 25 //y coordinate for center of items on "line 1" of the display
#define LINE2 115 //y coordinate for center of items on "line 2" of the display
#define LINE3 225 //y coordinate for center of items on "line 3" of the display - moved down 20 pixels from even spacing
#define LINE4 295 //y coordinate for center of items on "line 4" of the display
//LCD Variables
int wid; //Width of LCD (480)
int hei; //Height of LCD (320)
#define match(x, y, x1, y1, x2, y2) (((x > x1 && x < x2) && (y > y1 && y < y2))? 1 : 0)
char uparrow[2] = {24,0}; //Define string for up arrow character
char dnarrow[2] = {25,0}; //Define string for down arrow character
char rtarrow[2] = {26,0}; //Define string for right arrow character
char lfarrow[2] = {27,0}; //Define string for left arrow character
//Define the locations of all the buttons
#define STARTx (wid-BUTTONWID/2) //x coordinate for start/stop menu button - right
#define STARTy LINE1 //y coordinate for Start/stop menu button - top
//#define STOPx (wid-BUTTONWID/2) //x coordinate for stop menu button - right
//#define STOPy LINE1 //y coordinate for Sart menu button - top
#define UPx (wid-ARROWWID/2) //x coordinate for up button
#define UPy (LINE2-3-ARROWHEI/2) //y coordinate for up button
#define DNx (wid-ARROWWID/2) //x coordinate for down button
#define DNy (LINE2+3+ARROWHEI/2) //y coordinate for down button
#define MESSx (wid-BUTTONWID/2) //x coordinate for message/data button
#define MESSy (LINE4) //y coordinate for message/data button
// General global variables
char string1[80]; //Used to build strings to print
int ms; //Menu State - define names for each state to make it easier to undersand
int mi; //Menu item
int start; //0 if stopped, 1 if running
int view; //0 if data elements, 1 if show raw message data
int nummess; //Number of messages seen so far. Starts at NUMMESS which are defined, others are added as come in on CAN
//Menu definitions
#define TOP 0
#define NUMDATA 21 //Number of data elements
struct Data {
int mn; //message number
char dn[16]; //Data element name
char sb; //start bit
char len; //length
char en; //0 = MSByte first, 1 = LSByte first
char sn; //Signed = 1, unsigned = 0
float sc; //Scaling
float of; //Offset => Real = raw*scaling + offset
// float mnn; //Minumim value
// float mxn; //Maximum value
char unit[6]; //Unit string
float value; //floating point value
} Data[]= {
{1538,"Speed",38,16,0,1,1,-25000,"RPM",0},{1538,"DCV",31,9,0,0,1,0,"VDC",10.0},
{1538,"IGBT Temp",54,12,0,0,0.1,-50,"Deg C",0},{1792,"TqCmd",14,12,0,0,0.5,-600,"Nm",0},
{1792,"PSCmd",7,2,0,0,0,1,"",0},{1540,"Vbatt1",7,8,0,0,0.1,0,"V",0},
{1540,"IGN",51,8,0,0,0.1,0,"V",0},
#define NUMMESS 3 //Number of messages
static struct Message {
long id; //id = frame ID
int fl; //fl = frame length bytes
int by[8]; //Raw data
int rw; //rw = read/write, 0=read, 1 = write
int nd; //Number of data elements
int data[8]; //Array of pointers to data elements (index number
} Mess[40] = {
{1538,8,{10,20,30,40,50,60,70,80},0,3,{0,1,2,-1,-1,-1,-1,-1}}, //Hex ID 602
{1792,8,{10,20,30,40,50,60,70,80},1,2,{3,4,-1,-1,-1,-1,-1,-1}}, //Hex ID 700
{1540,8,{10,20,30,40,50,60,70,80},0,2,{5,6,-1,-1,-1,-1,-1,-1}} //Hex ID 604
#define CS 23 //Chip select pin
#define IRQ 21 //IRQ pin - must be interrupt capable
//Note that for Mega - pin 50 is MISO, 51 is MOSI, 52 is SCK.
//#define RX 4 //Receive data pin
//#define TX 5 //Transmit data pin
#define CF 16E6 //Clock frequency 8M or 16M
//Function to draw a rectangular button with text centered in the rectangle. x and y are center of button
void draw_button(char* label, int x, int y, int wid, int hei, int size, int textcolor, int buttoncolor, int radius) {
int labelwid; //Temp variable for width of text in pixels
mylcd.Set_Draw_color(buttoncolor); //Set button color
mylcd.Fill_Round_Rectangle(x-wid/2, y-hei/2, x+wid/2, y+hei/2, BUTTONRAD); //Draw the rounded rectangle
mylcd.Set_Text_colour(textcolor); //Set text color
mylcd.Set_Text_Size(size); //Set text size. Each char is 5x7 pixels * size. One pixel*size space
mylcd.Set_Text_Mode(1); //1 = don't use text background color
labelwid = strlen(label) * size * 6 - size; //Calculate length of string - in pixels. Account for 1/2 of last space
mylcd.Print_String(label, x-(labelwid/2), y-(size*7/2));//Draw the text in center of box
//Function to draw an arrow, many parameters are #defined. x and y are center of button
void draw_arrow(char* arrow, int x, int y, int invert) {
if (invert <= 0) {
draw_button(arrow, x, y, ARROWWID, ARROWHEI, ARROWTEXTSIZE, ARROWTEXTCOLOR, ARROWBUTTONCOLOR, ARROWRAD);
draw_button(arrow, x, y, ARROWWID, ARROWHEI, ARROWTEXTSIZE, ARROWBUTTONCOLOR, ARROWTEXTCOLOR, ARROWRAD);
//Function to draw a menu button, some parameters are #defined. x and y are center of button
void draw_menu_button(char* label, int x, int y, int textcolor, int buttoncolor) {
draw_button(label, x, y, BUTTONWID, BUTTONHEI, BUTTONTEXTSIZE, textcolor, buttoncolor, BUTTONRAD);
//Draw the main screen - only once when switching to it
void draw_main_screen() {
int textcolor = BLUE;
int buttoncolor = YELLOW;
draw_menu_button((char*)"Start", STARTx, STARTy, textcolor, buttoncolor); //Draw the Start/Stop button
draw_menu_button((char*)"Mess.", MESSx, MESSy, textcolor, buttoncolor); //Draw the Mess/Data button
draw_arrow(uparrow, UPx, UPy, NORMAL); //Draw an up arrow
draw_arrow(dnarrow, DNx, DNy, NORMAL); //Draw a down arrow
TSPoint read_TS(){
int x,y; //Temp variables for calculating x&y
static TSPoint p; //Statically define touchscreen point object
digitalWrite(13, HIGH); //Set chip select high
p = ts.getPoint(); //Get the point
digitalWrite(13, LOW); //Clear chip select
pinMode(XM, OUTPUT); //Reset the XM to output so LCD can use it
pinMode(YP, OUTPUT); //Reset the YP to output so LCD can use it
y = map(p.x, TS_MINX, TS_MAXX, hei, 0); //Map the raw touchscreen data to LCD coordinates - rotated!
x = map(p.y, TS_MINY, TS_MAXY, 0 ,wid); //Map the raw touchscreen data to LCD coordinates - rotated!
p.x = x; //Set the p.x value
p.y = y; //Set the p.y value
return p; //Return the point
void receiveCAN(int packetSize){ //This function is the callback for received CAN data
int i=0;
int j=0;
int om=0; //old message flag
int val;
float fval;
int bytes[8];
long id= CAN.packetId(); //Get message ID
int DLC = CAN.packetDlc(); //Get packet data length
// int packetSize = CAN.parsePacket(); //Get packetsize
digitalWrite(37, HIGH);
if (CAN.packetRtr()) return;
for (i=0; i< nummess; i++) { //Loop over messages in database so far
if (Mess[i].id == id) { //If there is a match
/* sprintf(string1,"Rec i=%d, id=%lx dl=%d\n",i,id, Mess[i].fl);
Serial.print(string1); */
om = 1; //Set flag that this message is already in database (old message)
j=0; //Zero the byte counter
while (CAN.available()) { //While there are available bytes to read
Mess[i].by[j++]= CAN.read(); //Grab the data
/* sprintf(string1,"Exist %d: id=%lX, ps=%d, Data = %02X %02X %02X %02X %02X %02X %02X %02X\n",i, id,Mess[i].fl,Mess[i].by[0],Mess[i].by[1] ,Mess[i].by[2],Mess[i].by[3],Mess[i].by[4],Mess[i].by[5],Mess[i].by[6],Mess[i].by[7]);
Serial.print(string1);*/
if (om == 0) { //Else this a new message
/* sprintf(string1,"New %x\n",id);
Mess[i].id = id; //record message ID
Mess[i].fl = packetSize; //Record # data bytes
/* sprintf(string1,"New %d: id=%lX, ps=%d, Data = %02X %02X %02X %02X %02X %02X %02X %02X\n",i,id,Mess[i].fl,Mess[i].by[0],Mess[i].by[1] ,Mess[i].by[2],Mess[i].by[3],Mess[i].by[4],Mess[i].by[5],Mess[i].by[6],Mess[i].by[7]);
nummess++; //Increment number of messages in database
if (i < NUMMESS) {
for (j=0;j<Mess[i].nd;j++) { //Loop over the number of data elements in the received message
val = element(Mess[i].by,Data[Mess[i].data[j]].sb,Data[Mess[i].data[j]].len); //Retrieve the integer value
fval = (float)val*Data[Mess[i].data[j]].sc + Data[Mess[i].data[j]].of; //Use scaling and offset to get floating point value
if (packetSize != 0) {
Serial.print("Got second message\n");
digitalWrite(37, LOW);
int element(int* bytes, int st, int len) { // This function returns value from 8 byte array big endian format
unsigned long data;
unsigned int val;
int startbit;
data=(unsigned long)bytes; //Cast the data into an unsigned long
startbit=8*(st>>3)+(7-st<<3); //Calculate start bit in order of bytes
val=data>>(64-(startbit+len)); //Shift data so that what we want is in lowest bits
val &= ((1<<len)-1); //Mask off unused high bits
return val; //Return the value
void splash() {
mylcd.Set_Text_Size(TITLETEXTSIZE+2); //Set text size. Each char is 5x7 pixels * size. One pixel*size space
mylcd.Set_Text_colour(BLUE); //Set text color
mylcd.Print_String((char *)"CAN Viewer",CENTER,50); //First part of splash screen
delay(500); //Wait 1/2 sec
mylcd.Set_Text_Size(TITLETEXTSIZE-1); //Set text size. Each char is 5x7 pixels * size. One pixel*size space
mylcd.Print_String((char *)"by", CENTER, hei/2); //Next part of splash screen
mylcd.Print_String((char *)"RJH",CENTER,hei*3/4); //Last part of splash screen
delay(1000); //Wait 1 second
int i;
CAN.setPins(CS,IRQ); //Set Chip select and interrupt pins for SPI to CAN chip
CAN.setClockFrequency(16e6); //Set CAN clock frequency
CAN.onReceive(receiveCAN); //Set callback function for reception of CAN message
mylcd.Init_LCD(); //Instantiate LCD
// Serial.println(mylcd.Read_ID(), HEX); //Print LCD ID to serial port
mylcd.Set_Rotation(3); //Set lndscape mode, USB on right side
mylcd.Set_Text_Mode(1); //Set text mode to no background color
mylcd.Fill_Screen(BLACK); //Set screen to black
wid = mylcd.Get_Width(); //Get width (480 pixels)
hei = mylcd.Get_Height(); //Get height (320 pixels)
splash(); //Show splash screen
ms = TOP; //Set menu state to TOP
mi = 0; //Set menu item to 0 - this is used to scroll through data
view=0; //0 means show data elements, not raw messages
nummess=NUMMESS; //Start with number of messages defined
mylcd.Fill_Screen(BLACK); //Clear screen
draw_main_screen(); //Draw initial screen
show_data(0);
pinMode(37, OUTPUT);
void show_data(int mi) {
int i,j;
j= min(NUMDATALINES,NUMDATA);
mylcd.Set_Text_Size(DATATEXTSIZE); //Set text size. Each char is 5x7 pixels * size. One pixel*size space
mylcd.Set_Text_colour(GREEN); //Set text color for title line
mylcd.Print_String("Item Name Value Unit",0,DATAy-5); //Write the title line
mylcd.Set_Text_colour(WHITE); //Set text color
for (i=0; i< j; i++) { //Loop over the data elements to show
mylcd.Print_String(Data[i+mi].dn,0,50+(i+1)*9*DATATEXTSIZE); //Write the name
mylcd.Print_String(Data[i+mi].unit, 21*6*DATATEXTSIZE, 50+(i+1)*9*DATATEXTSIZE);//Write the unit
update_data(0);
void update_data(int mi) {
int i,j ;
dtostrf(Data[i+mi].value,7, 1, string1);
mylcd.Print_String(string1, 13*6*DATATEXTSIZE, 50+(i+1)*9*DATATEXTSIZE);
void show_mess(int mi) { //This function shows the message screen - all the static items.
int i,j; //Local variables
j= min(NUMDATALINES,nummess);
mylcd.Print_String("ID Data Bytes",0,DATAy-5); //Write the title line
for (i=0; i< j; i++) { //Loop over the messages to show
sprintf(string1,"%03X",Mess[i+mi].id); //Construct the string - message ID is 11 bits so 3 characters
mylcd.Print_String(string1,0,50+(i+1)*9*DATATEXTSIZE); //Write the name
update_mess(0); //Show all the actual data
void update_mess(int mi) { //This fucntion shows teh message data - no need to redraw the static items
int i,j,k; //Local variables
j= min(NUMDATALINES,nummess); //Calculate the max number of items to show
for (i=0; i< j; i++) { //Loop over the message IDs
for (k=0;k<Mess[i+mi].fl;k++){ //Loop over the number of bytes to print
sprintf(string1,"%02X",Mess[i+mi].by[k]); //Construct the string
mylcd.Print_String(string1, (4+k*3)*6*DATATEXTSIZE, 50+(i+1)*9*DATATEXTSIZE); //Print the string to screen
#define LOOPDELAY 100
void clear_data_area(){
mylcd.Set_Draw_color(BLACK);
mylcd.Fill_Rectangle(0,DATAy+9*DATATEXTSIZE,DATAx,hei);
int i,j,textcolor,buttoncolor; //Local variables
int packetSize=0;
TSPoint p; //Declare the touchscreen variable
/* if (start) {
// sprintf(string1,"RPS %d\n",packetSize);
// Serial.print(string1);
if (packetSize) {
receiveCAN(packetSize);
// sprintf(string1,"St=%d, ps = %d\n",start,packetSize);
switch (ms) { //Switch on menu state
case TOP:
p=read_TS(); //Call the touchscreen input function
if (p.z > TOUCHTHRESH){ //This is true if there is a touchscreen press
if(match(p.x,p.y,STARTx-BUTTONWID/2,STARTy-BUTTONHEI/2,STARTx+BUTTONWID/2,STARTy+BUTTONHEI/2)) {//Check if press is on this rectangle
textcolor = BLUE;
if (start) { //If running
draw_menu_button((char*)"Start", STARTx, STARTy, textcolor, buttoncolor); //Draw the Stop button
start = 0; //Set next state to stopped
CAN.end();
} else { //It is stopped
draw_menu_button((char*)"Stop", STARTx, STARTy, textcolor, buttoncolor); //Draw the Start button
start = 1; //Set to running
CAN.setSPIFrequency(5E6);
if (!CAN.begin(500E3)) {
Serial.println("Starting CAN failed!");
while (1);
} else Serial.println("Can started");
if(match(p.x,p.y,MESSx-BUTTONWID/2,MESSy-BUTTONHEI/2,MESSx+BUTTONWID/2,MESSy+BUTTONHEI/2)) {//Check if press is on this rectangle
textcolor = BLUE;
if (view) { //If view =1, that means in message mode
draw_menu_button((char*)"Data", MESSx, MESSy, textcolor, buttoncolor); //Draw the Data button
view = 0; //Set next state to data mode
mi = 0; //Reset the data counter to zero
show_data(mi); //Sow the data
} else { //It is in data mode
draw_menu_button((char*)"Mess.", MESSx, MESSy, textcolor, buttoncolor); //Draw the Message button
view = 1; //Set to message mode
show_mess(mi); //Show the messages
if(match(p.x, p.y, UPx-ARROWWID/2,UPy-ARROWHEI/2,UPx+ARROWWID/2,UPy+ARROWHEI/2)) { //Check if press is on this rectangle
draw_arrow(uparrow, UPx, UPy, INVERT); //Draw an up arrow inverted
delay(PRESSDELAY); //Delay before redrawing button
// sprintf(string1,"mi=%d, NUMDATA=%d, NDL=%d\n",mi,NUMDATA,NUMDATALINES);
if (view) { //It is in message mode
if ((mi < NUMMESS) && (NUMMESS-mi > NUMDATALINES)) { //Check if OK to scroll
mi++; //increment mi only if not all data fits
clear_data_area(); //Need to clear screen and redraw the data. Depends on view also.
show_mess(mi); //Redraw data - after incremened mi
if ((mi < NUMDATA) && (NUMDATA-mi > NUMDATALINES)) { //Check if OK to scroll
show_data(mi); //Redraw data - after incremened mi
if(match(p.x, p.y, DNx-ARROWWID/2,DNy-ARROWHEI/2,DNx+ARROWWID/2,DNy+ARROWHEI/2)) { //Check if press is on this rectangle
draw_arrow(dnarrow, DNx, DNy, INVERT); //Draw a down arrow inverted
if (mi > 0) {
mi--; //decrement mi
delay(LOOPDELAY); //Delay per loop execution
