Since version 1.8.1 was released, I can no longer find the 'esp8266' board package by 'ESP8266 Community' in the Board Manager. I did have it installed on my desktop before, but I cannot install it on any other computer now. Does anyone know a reason why it has been removed, or a workaround to connect to an 'Adafruit HUZZAH ESP8266' board?
To answer my own question, I rebooted the PC and opened Arduino again and went to Boards Manager. The ESP8266 option was there.
I had just installed Arduino 1.8.1 today, found out I had to add the board to the dialout option (see the Linux instructions for installation) and logout and login again. I wonder if the logout and login process would have also worked in giving the Arduino IDE access to the ESP8266 boards in Boards Manager?
The version of the Arduino IDE you get from the package managers is extremely outdated and sometimes modified in strange ways. Don't ever use apt-get or whatever to install the Arduino IDE, it will always cause you problems. Instead, just download and install the official version of the Arduino IDE from:
I have had the same type of issue with the board manager but for different reasons. I discovered that logging on to the same machine on the same network, but as a different user, I could install the IDE with a working board manager. The problem was therefore in my Windows 10 Profile. Rather than rebuild my profile (arduous at the best of times) I discovered that the "uninstall" tool left a number of old files in the Windows Registry, and re-installing the Arduino IDE did not remove them. So I manually deleted all Adruino files in the registry (be careful - take out an essential file accidentally and you are dead meat). Then I did a fresh install - problem solved.
