Mac 10.7.5
Leonardo and Uno
I was able to upload from my computer until recently. Changes since my last Arduino project that may have effect: recent update to Java, and installation of Emacs for a course I enrolled in and subsequently dropped. I removed Emacs with AppCleaner with no change.
I have tried the troubleshooting steps from the Guide. I can see my Arduino on the serial port, and it gets power and the L LED is lit. I tried a Loop-back test and, believing I did it right, it passed. (During the Loop-back test, I observed the Tx and Rx LEDs on the board lighting up every time I pressed a key, and with the Terminal screen split, I saw the letters typed appear in the second pane.)
I am able to successfully upload a sketch from another MacBook with the same OS version. I have tried rebooting and repairing permissions on my own MacBook Pro with no change. I don't know how to see what if anything is holding on to my serial port, if that is what is keeping the Arduino from responding.
With thanks in advance, can someone help me get my upload functionality back?
verbose output from Leonardo:
Binary sketch size: 6,064 bytes (of a 28,672 byte maximum)
Forcing reset using 1200bps open/close on port /dev/cu.usbmodemfa131
PORTS {/dev/tty.usbmodemfa131, /dev/cu.usbmodemfa131, /dev/tty.Bluetooth-Modem, /dev/cu.Bluetooth-Modem, /dev/tty.GavinsiPhone-WirelessiAP, /dev/cu.GavinsiPhone-WirelessiAP, /dev/tty.Bluetooth-PDA-Sync, /dev/cu.Bluetooth-PDA-Sync, } / {/dev/tty.usbmodemfa131, /dev/cu.usbmodemfa131, /dev/tty.Bluetooth-Modem, /dev/cu.Bluetooth-Modem, /dev/tty.GavinsiPhone-WirelessiAP, /dev/cu.GavinsiPhone-WirelessiAP, /dev/tty.Bluetooth-PDA-Sync, /dev/cu.Bluetooth-PDA-Sync, } => {}
Uploading using selected port: /dev/cu.usbmodemfa131
/Applications/Arduino.app/Contents/Resources/Java/hardware/tools/avr/bin/avrdude -C/Applications/Arduino.app/Contents/Resources/Java/hardware/tools/avr/etc/avrdude.conf -v -v -v -v -patmega32u4 -cavr109 -P/dev/cu.usbmodemfa131 -b57600 -D -Uflash:w:/var/folders/v3/t3w8h12n7d11rxr23js97_5c0000gn/T/build2180696007194724475.tmp/MIDI_STEPPER_SANDBOX_V6.cpp.hex:i
avrdude: Version 5.11, compiled on Sep 2 2011 at 18:52:52
Copyright (c) 2007-2009 Joerg Wunsch
System wide configuration file is "/Applications/Arduino.app/Contents/Resources/Java/hardware/tools/avr/etc/avrdude.conf"
User configuration file is "/Users/gavin/.avrduderc"
User configuration file does not exist or is not a regular file, skipping
Using Port : /dev/cu.usbmodemfa131
Using Programmer : avr109
Overriding Baud Rate : 57600
AVR Part : ATmega32U4
Chip Erase delay : 9000 us
PAGEL : PD7
BS2 : PA0
RESET disposition : dedicated
RETRY pulse : SCK
serial program mode : yes
parallel program mode : yes
Timeout : 200
StabDelay : 100
CmdexeDelay : 25
SyncLoops : 32
ByteDelay : 0
PollIndex : 3
PollValue : 0x53
Memory Detail :
...much of this report has been edited for brevity due to character restrictions on the post. All text preserved in the attachement.....
avrdude: verifying ...
avrdude: 6064 bytes of flash verified
avrdude: Send: L [4c]
avrdude: Recv: . [0d]
avrdude: Send: E [45]
avrdude done. Thank you.
verbose from leonardo.txt (97.4 KB)
